Sponsored by: Real Truck
front axle
Old Apr 24, 2013 | 12:42 PM
SleepinSHO91's Avatar
SleepinSHO91
front axle
Just wondering if its normal that my front axle sits out about 1 1/2 inches further on the drivers side than the passenger, also anyone else have a problem with the gas pump always shutting off when filling up...thanks, Rob
Old Apr 24, 2013 | 12:51 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Just to confirm, what year and 2wd or 4wd? (I'd guess '05 4wd, but assuming is usually a bad idea) Do you have some type of lift on the truck? Is it tracking normally and acting normally even with the axle shifted over?
Something like a 4"+ lift on an 05+ without trac bar correction could conceivably end up with the axle severely shifted to the driver's side.
Old Apr 24, 2013 | 01:45 PM
SleepinSHO91
It's an 05 4x....has a 2 1/2 leveling kit, that's it...it tracks like it should, I don't any left or right pull, just thought it was weird being wider on one side...
Old Apr 24, 2013 | 02:41 PM
texastech_diesel
Token Redneck
It's not wider, it's out of center because the axle falls on a radius. The three solid mounting points between the axle and frame are where the track bar and two radius arms bolt up so everything moves in relation to those points; as the suspension extends the axle moves rearward and to driver's side. I was just just under an inch out of center with a 2" kit and didn't mess with it. If it bugs you, your choices are to find a trac bar drop bracket for your height of kit, or an adjustable trac bar bracket.
Old Apr 24, 2013 | 05:53 PM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by SleepinSHO91
....................... also anyone else have a problem with the gas pump always shutting off when filling up...thanks, Rob
TSB
06-19-15
SLOW FUEL FILL
Publication Date: September 18, 2006
FORD:
2005-2007 F-250, F-350
ISSUE:
Some 2005-2007 F-Super Duty 250/350 vehicles may experience premature automatic shut off of the fuel fill nozzle, or repeated fuel shut off at the fuel station delivery nozzle. Vehicles operated in muddy or dusty environments can encounter a dirt-clogged carbon canister system. More specifically, the carbon canister's vent, fresh-air box, and filters, clogged with dirt from operating in such environments.
ACTION:
Use the following Service Procedure to resolve the concern if the carbon canister system is dirt clogged.
NOTE: THIS TSB ONLY APPLIES TO F-250/350 PICKUPS, AND F-250/350 PICKUP BOX DELETE / CHASSIS CAB VEHICLES.
SERVICE PROCEDURE
Inspect the vehicle carbon canister system and if it is found to be dirt clogged then continue with this TSB.
NOTE: IF THE VEHICLES CARBON CANISTER SYSTEM IS NOT DIRT CLOGGED, THEN PROCEED WITH NORMAL DIAGNOSTICS AND DO NOT CONTINUE WITH THIS TSB.
Vehicles with Pick Up Boxes:
If the vehicle was built on or after 9/14/2006, proceed to Step 2. If the vehicle was built prior to 9/14/2006, replace the carbon canister assembly. This carbon canister has a revised internal filter media.
Relocate the fresh-air intake port to a more protected location using the Fresh Air Hose Kit, for pick up applications only.
Vehicles with Pick Up Box Removed or Chassis Cab:
Relocate the fresh-air intake port to a more protected location using QVM bulletin Q-132 at the body builder's website - https://www.fleet.ford.com/truckbbas/index.htm for fresh air intake routing recommendations.
PART NUMBER PART NAME
7C3Z-9049-A Fresh Air Kit
6C3Z-9D653-AB Carbon Canister - Pick up
6C3Z-9D653-DB Carbon Canister - Chassis Cab
Old Apr 24, 2013 | 07:56 PM
99f350sd's Avatar
99f350sd
Get an adjustable track bar. If you lift it up its gonna move over. Its not right and may wear parts early.
Oh! many trucks are off a little.. Check another like yours first..
Dick
Old Apr 25, 2013 | 02:54 PM
SleepinSHO91
thanks for the info guys, ill leave the front alone, the fuel thing should be under my warranty, so ill check into getting it fixed
fordman19762003
Jul 8, 2019 12:35 AM
Silver04s
Mar 12, 2019 08:38 AM
pin8246
Aug 10, 2012 07:55 PM
Unrealo4
Nov 30, 2010 10:32 PM
kshaneh
Feb 22, 2009 07:59 PM
