Front axle
Old Feb 22, 2009 | 04:42 PM
kshaneh's Avatar
kshaneh
Question Front axle
I have a 78 f150 4x4, the front axle looks like it sticks out on the driver side and on the passenger side its sucked. have any ideas as to why it looks like this? do you want to see pics, if so tell me of what and i can have them on within 5 minutes. thanks for any information
Old Feb 22, 2009 | 06:39 PM
kingford72's Avatar
kingford72
does your truck have any lift to it. Its because your track bar runs from the driver side of the frame to the pass. side of the axle, so when it compresses, it move sideways toward the pass. side a little bit. When you lift your front end the idea is to keep your track bar and drag link as close to the same angle as posible, so they give you a drop bracket for the track bar and that can have a effect on where the axle sits under the truck too.
Old Feb 22, 2009 | 07:09 PM
kshaneh's Avatar
kshaneh
no i dont heave ne lift
Old Feb 22, 2009 | 07:54 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Bent frame? Or body? Different wheel offsets?
Old Feb 22, 2009 | 07:59 PM
kshaneh's Avatar
kshaneh
could be the body cause the front cab mounts are gone, and i bolt attaching the cab to the frame
