Sponsored by: Real Truck
Front Axle shift
Old Nov 30, 2010 | 10:16 PM
Unrealo4's Avatar
Unrealo4
Front Axle shift
Ok I have a 2004 F350 CC SRW. It has a Add-a-leaf leveling kit the previous owner added to it everything else is stock. Ive been noticeing that the front axle is sticking out a bit more on the drivers side. At first I thought my mind was playing tricks on me. but then I noticed things like the drivers side door getting road splash on it and not the passengers side. The best I can see its sticking about a 1/2"-3/4" out more on the drivers side. Anyone know whats causeing this? or a way to fix it?
Thanks
Old Nov 30, 2010 | 10:32 PM
Grumpy Moose's Avatar
Grumpy Moose
When he lifted the front, he probably didn't relocate the track bar, or did it incorrectly. Most lift kits either come with some kind of new bracket or new bar itself to make up the difference and keep the front axle centered. If your track bar is adjustable, given that the axle is located too far to the left, you would need to lengthen the bar to bring the axle back under the truck. Otherwise, you can call around to some of the lift kit manufacturers to see if they have something that might work for your truck.
Ford11
Jan 24, 2021 12:06 PM
gramesj
Oct 18, 2016 10:45 PM
gramesj
Oct 17, 2016 12:14 PM
harryball42
Jun 10, 2015 07:52 AM
compete
Jun 12, 2005 05:42 PM
