92 f150 sleeper
92 f150 sleeper
I want to turn my 92 f150 into a sleeper and I have some questions of what the best route would be to go about getting more acceleration and mid range power, the truck currently has a 351 Cleveland with an automatic 2wd c6 tranny and h9 rear end, would I be able to swap the auto tranny out with a 5 speed tranny? Also I was reading up on putting a chip in the truck to give it more Hp and acceleration, I still nee the truck to have enough power to pull and haul things for the summer before I go full ***** to the wall with this truck and make it strictly for showing off then pulling and hauling. I red up on some chips that may help they both claim to increase my Hp by 60 horses and also increase fuel economy and acceleration. what I would like to know which is the best chip, i only did a little research and the best 2 chips so far i could find are the Gforce performance chip and the PCD performance chip, which is best? Also what would be the best spark plugs to put in it for a tune up? Any help would be greatly appreciated thanks!!!
You or someone must of installed the 351 Cleveland, what year is it? You'll have trouble putting a 5 speed in The Cleveland was never used in the truck.
A Cleveland shouldn't need much to go all out. The other problem is what computer was used the Cleveland never was used with a factory computer vehicle so it must be aftermarket. I can't imagine someone installing a 351 Cleveland & not setting it up to go all out.
Craig
Craig
I agree with Craig on this. It doesn't sound stock so things may be a little harder to mod since the truck sounds "custom built" with that drive line but I may be wrong. Building a sleeper is easy though. Some nice headers and good flowing exhaust with quiet mufflers.
In the engine a mild cam, some nice heads and a intake will give you a real stout motor.
Trans wise if you wanna go 5-speed then go for it but the c6 is a really stout auto trans and if you wanna you can even buy a floor shifter for it to give it that manual feel, but that's just my $.02.
To look at a 351 Cleveland it looks like a 400 or 460 in size. I never have seen on with with a stock computer set up. You would have to upgrade almost everything to use a 351 Cleveland. Not to mention 351 Cleveland's are fairly rare.
If everyone that claims to have a 351 Cleveland had one there would be more now than ever made.
I go to car shows all the time, I go to Barrett-Jackson yearly & I never see a 351 Cleveland, except in a period correct Ford/Mercury, & they are very rare. The one I see the most is my buddy has a Cougar with a 351 Cleveland. That came from the factory equipped with the Cleveland engine. A fairly rare convertible car.
Show us a picture?? That will answer the question once & for all. I bet its a 351 Windsor stock in 1992 F150s.
Craig
Craig
NOT a Cleveland. it is a Windsor engine
Also it does NOT have a 9" rear, it is a 8.8
HIGHLY doubtful you have a C6 either
No chip will give you even 25hp. You have to bolt parts on or tear into the engine
What HP number are you looking to hit
As you guys that have been around here know, many more don't know the difference between a Cleveland and any other 5.8L. I'm an old man I remember seeing them run back in the day. It is about like the real 289 Hi Performance engine. most don't know they ran a solid lifter cam. They were much more potent than a 302 HO.
Anyway, when he posts a picture of his engine it will be clear, even a bad picture will tell the story, because a Cleveland looks nothing like a Windsor.
Craig
