a/c flush
Old Apr 23, 2013 | 06:02 PM
V10man's Avatar
V10man
a/c flush
I need to flush the a/c system. The condensor and evaporator. How does everyone do it? Autozone has a kit you can rent for $40 but I think you have to buy the flush stuff. Is there a way a shade tree mechanic can do this at home?
Old May 2, 2013 | 09:02 AM
lsrx101's Avatar
lsrx101
You need a fully evaporating solvent that won't leave a residue to flush AC parts. You also need access to LOTS of compressed air, something along the lines of 15cfm or more. (5hp, 2 stage, 60-80 gallon compressor) The system needs to be DRY when you're finished.
The solvents that I've seen at the parts stores lately are citrus based and leave lots of residue. I can't say that they don't work, but I don't trust the residue they leave behind. It's made to break down the old oil so the residue would also break down the new oil.
I use a product called Dura-II which is specifically made for AC systems. I've also used laquer thinner or isopropyl alcohol as needs dictated.
As far as flushing the condenser;
-If you are just flushing to remove the old oil, you should be fine.
-If you have had a compressor failure, REPLACE the condenser. It cannot be reliably flushed even with professional equipment.
Hope this helps.
cohomology
Jul 8, 2016 09:19 AM
Foxhound^
Aug 15, 2011 07:54 PM
ar1953
21
Aug 8, 2008 09:36 AM
Sullivan
Jul 29, 2007 09:51 PM
Black Ford XLT
Jun 12, 2006 06:36 PM
