5 speed question
Old Apr 23, 2013 | 04:32 PM
MilllerTime's Avatar
MilllerTime
5 speed question
My 64 f100 has a 85 gt 302 with a c6. I would love to have a 5 speed trans but didn't know what I could pull one out of. Are the bell housing still interchangeable? I know I could find 90s 5 speed out of a f150 but didn't know if that would work. Or a zf 6 speed in the 250s or 350s? Just throwing ideas out their. Any response would be helpful. Thanks
Hunter
Old Apr 23, 2013 | 04:49 PM
jowilker's Avatar
jowilker
Hunter, To go to a manual, you gotta add clutch and a lot of other stuff. Have you thought of swapping to an AOD? That will give you OD and retain what it currently there.
John
Old Apr 23, 2013 | 05:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1983/97 F250/350 460 & diesels, 1984/96 F150/350 300/302/351W all have a hydraulic clutch.
Old Apr 24, 2013 | 11:53 AM
MilllerTime
Well right now the body is off so now would be the time to do it if ever. But this is only the option if I find a good one at the junk yard. I've done a little research so I'm looking for a m5od or a zf 5 96 or before if I'm correct? I believe the zf 5 will work as long as it comes off of a small block. The m5od is probably the better choice but the zf is stronger. Correct me if I'm wrong on any of this. Thanks guys.
Daltonsheets1995
Jun 22, 2012 12:05 PM
Thumper1984
Jan 31, 2011 02:59 PM
rmark940
Nov 22, 2009 01:15 PM
highpockets58
Jan 17, 2008 05:49 PM
Richard68
Feb 18, 2004 05:58 PM
