5 speed tranny?
Old Jun 19, 2012 | 01:26 PM
Daltonsheets1995's Avatar
Daltonsheets1995
5 speed tranny?
What's the name if a 5 speed manual fordtransmissions for our trucks?
Will a 5 speed from the 87-91 work on on our trucks?
Old Jun 19, 2012 | 02:08 PM
Rogue_Wulff's Avatar
Rogue_Wulff
There were 2 different 5 speed trans used in the 87+ F series trucks.
F150's used a M5OD (Mazda 5 speed OverDrive) behind a 300 I-6 or 302 V8. I am not sure if the 351 V8 could be ordered with a 5 speed in an F150, or which trans would be used if it was.
F250's and above, used a ZF 5 speed. This could be found behind any of the engines offered in these trucks, and there were 3 different models for any given year. 351W used 1 to fit the small block bellhousing pattern, 460 needed it's own, as did the diesel.
Either of these can be swapped into older trucks. Both use a hydraulic-actuated clutch, so anything older than ~1984 will need to be converted to use the hydraulic system. The main item, is finding the correct bellhousing pattern if you go ZF. The M5OD is small block only.
Clutch assembly, flywheel, crossmember, and driveshaft may all be needed to complete the swap, along with other bits and pieces. But it can be done, and has been many times.
Old Jun 19, 2012 | 10:17 PM
Daltonsheets1995
How hard is it to find a M5OD? like at a junk yard or something?
Old Jun 20, 2012 | 12:57 AM
Rogue_Wulff
Shouldn't be too difficult, as they were used in plenty of trucks. Just make sure it's from a 87-91 model, since they speedo cable hole disappeared sometime after the end of the 91 model year. They went to an electric speedo, driven off the speed sensor for the ABS on the rear axle housing.
Old Jun 21, 2012 | 05:25 PM
whisler's Avatar
whisler
Light duty F250 used the M5OD behind the 302 engine, at least in '89, because I have one.
Old Jun 21, 2012 | 05:55 PM
Dave804's Avatar
Dave804
Rogue, will the 351 ZF Fit a 300 engine, or is a different bell housing needed?
And the various support and mating hardware you mentioned, is any less of that required for a swap from an 80-86?
And I remember some of the 95+ SD's had a ZF-5. Looks like a different part number, different ratios though.
Old Jun 21, 2012 | 10:54 PM
ctubutis's Avatar
ctubutis
351.... Wheezer? Cleveland? M-block? There are three 351s but I'd guess you're talking about a Wheezer, it was the only one around when the ZF came about.
Old Jun 22, 2012 | 12:05 PM
Rogue_Wulff
The 351W ZF will fit a 300. The bellhousing is part of the case, and cannot be changed without cutting/welding.
Depending on the year, there can be more or less stuff needed to do the swap. 80-83 used a mechanical clutch linkage, 84+ went to hydraulic. This mean the pedals have to be for the hydraulic setup, as all ZF's were hydraulic. The 351 version has an internal slave.
Yeah, there were a couple different models of ZF used over the years, most notable differences were the ratios inside. For going into an 80-86 2wd, you have to make sure the trans has the speedo drive. 4wd doesn't make any difference, since the speedo is driven in the transfer case.
Daltonsheets1995
Nov 27, 2012 01:20 AM
lilreddevilF-100
Jun 28, 2011 10:38 PM
highpockets58
Jan 17, 2008 05:49 PM
Richard68
Feb 18, 2004 05:58 PM
JF5speed
Sep 29, 2002 06:55 PM
