68 five speed conversion
Old Feb 17, 2004 | 11:31 AM
Richard68's Avatar
Richard68
Question 68 five speed conversion
I have my four speed out for a rebuild now and am asking myself if I want to finish the job or start a new adventure by putting a later model 5 speed in the truck. It has a 300 CID engine. Does anyone know if a later Ford five speed will match the bell housing and input shaft? If this has been asked and aswered before, a little direction to the link would be appreciated.
Old Feb 17, 2004 | 07:20 PM
steell's Avatar
steell
Depends on what five speed trans you are asking about. T-5 won't work with your bellhousing, and M5OD and ZF five speed truck transmissions have an intregal bellhousing, and use an internal hydraulic slave cylinder for the clutch.
M5OD and ZF off a 4.9L six and 5.0/5.8 (302/351) will bolt up to your engine.
Old Feb 18, 2004 | 09:29 AM
Richard68's Avatar
Richard68
Thanks Steell, that was the information I was looking for. Can you tell me what the high gear gear ratios are for both transmissions and what year trucks they would have been installed in?
Old Feb 18, 2004 | 05:58 PM
steell's Avatar
steell
88-96 Broncos thru F350's and somewhere around .7 to .8 in Overdrive (5th).
Pwright
Aug 26, 2009 11:46 AM
redlightning
Mar 24, 2006 11:46 AM
tom_jarz
20
Feb 18, 2005 12:53 PM
snow
Jan 2, 2003 06:55 AM
TheFonz
Jul 30, 2000 10:24 AM
