miss at idle
Old Apr 22, 2013 | 11:28 PM
speedracer54729's Avatar
speedracer54729
miss at idle
Hey I have A 92 ranger 4.0 5speed 4x4. There's new E3 plugs in it wires are new no miss when driving but ideling sounds like I have a 351 with a hudge cam in it lol. Not like thats a bad idea. any help please?
Old Apr 23, 2013 | 08:31 AM
Furyus1's Avatar
Furyus1
Pull those E3 plugs out and put in the proper Motorcraft plugs and see if that makes any difference. Also, did you use Motorcraft wires or aftermarket? Between the plugs and wires, you're probably not generating enough energy to provide proper spark to the cylinders which might be what is causing your loping idle.
Old Apr 23, 2013 | 08:58 AM
pawpaw's Avatar
pawpaw
^+1 on the plugs & wires, especially if the problem came about after the new plugs, or wires were installed!!!!
Old Apr 23, 2013 | 06:58 PM
speedracer54729
This lopeing was before plugs n wires
Old Apr 23, 2013 | 08:47 PM
pawpaw's Avatar
pawpaw
OK, so do you have a CEL lit????
Old Apr 23, 2013 | 09:03 PM
Hank85713's Avatar
Hank85713
I developed a miss last summer, replaced all the ignition components still had it. I changed the injectors and it went away. so when its running try to listen and check if the injectors are working or not. use a stethescope ($5 at harbor freight) or you can use a long screw driver to transfer the noise to your ear.
Old Apr 24, 2013 | 01:25 AM
speedracer54729
whats a cel?
Old Apr 24, 2013 | 08:33 AM
Furyus1's Avatar
Furyus1
Originally Posted by speedracer54729
whats a cel?
Check Engine Light
Old Apr 24, 2013 | 09:03 PM
speedracer54729
lol duh no i dont n no codes come up
Old Apr 24, 2013 | 09:10 PM
JWC 3's Avatar
JWC 3
Check above , and firing order . If all that good , check for a burnt valve . It still happens . Runs good , miss at idle . Could be a valve issue . Just a thought !
Xtrophy
Dec 24, 2013 03:43 PM
roree
Aerostar
Mar 27, 2005 12:09 AM
dcg4403
1997 - 2003 F150
Sep 25, 2004 01:33 AM
bronconorwood
1978 - 1996 Big Bronco
Jul 25, 2004 06:28 PM
billj6
May 31, 2004 01:01 PM
