OEM Fuel Pump Capabilities
2006 F-350 Lariat 6.0L CC SRW SB Fx4
Please let me know if the OEM frame-rail mounted fuel pump/filtration
system will support a regulated return system with 175/30%
sticks, Garrett Powermax and Magnaflow 3.5" down to 4" w/
86ed~kitty?
Much appreciated!
This Link May Be Of Interest: http://www.strictlydiesel.com/Produc...pSelection.pdf
OEM framerail fuel unit issues feeding larger sticks:
Some sources have stated that the OEM framerail system will adequately supply up to 190 sticks reliably when paired with a well designed RRFS having larger ID lines and banjoes plus 'custom machined regulator housing assembly'. Dead-end elimination reduces pump demand with reduced resistance.
I have an AD II -165 which I will not employ (reasons ~ see info below)!
A) Will a regulated return fuel system eliminate the OEM fuel pump supply issues feeding upgrade injectors?
A2) Was the OEM 155 injector feed weekness without a regulated fuel return installed?
A3) Can "falling on it's face" a few times due to weak OEM system supply damage the injectors?
A4) Was the aggressive tune weakness with OEM pump & sticks through dead-end or RRFS?
B) Which fuel pump/filtration/H2O separation system are you using with upgrade (175/30 and up) sticks and aggressive tuning?
C) Anyone: Please reply with proven brands/sources for brush or brushless pump/filtration/separation systems for the 6.0l with Powermax, 175/30's, Magnaflow ~ no cat, AFE intake, RRFS?
<1/4 level tank draw issues:
They also say that 1/4 and below tank fuel draw problems may come from larger or poorly installed pickup tube especially when devoid of a transfer pump. Some OEM plastic pickup screens may dislodge/break from sloshing or degradation (mostly on older units) which raises the draw a few inches from the original pickup level.
*Buyer Beware:
What I have read and heard leads me to believe that the AirDog II-165 and other PureFlow AD models have design inadequacies and are leaving many powerstrokers stranded roadside.
Engineering flaw consequences include overheating due to motor weakness and a thin wiring harness plus internal shorting after defective shaft seal failure. These pumps were originally designed as forwarding units until being stretched beyond their means as high demand systems.
Potential damage to injectors etc during pump failure at speed is a likely side-affect.
Thanks again.
I have an AD II -165 which I will no employ (reasons ~ see info below)!
A) Will a regulated return fuel system eliminate the OEM fuel pump supply issues feeding upgrade injectors? Simply put NO it won't.
A2) Was the OEM 155 injector feed weekness without a regulated fuel return installed? I have OEM injectors (witch BTW are not 155's) with a regulated return, and the stock pump had a hard time keeping up with the demands of aggressive tuning.
A3) Can "falling on it's face" a few times due to weak OEM system supply damage the injectors? Yes!! any pressure under 45 PSI can cause injector damage
A4) Was the aggressive tune weakness with OEM pump & sticks through dead-end or RRFS? Answered above. OEM pump with agreesive tuning will have a hard time keeping up with or without a RR
B) Which fuel pump/filtration/H2O separation system are you using with upgrade (175/30 and up) sticks and aggressive tuning? Currently using a FASS 150/180, but I will be switching to the AD soon because of repeat failures with the FASS.
C) Anyone: Please reply with proven brands/sources for brush or brushless pump/filtration/separation systems for the 6.0l with Powermax, 175/30's, Magnaflow ~ no cat, AFE intake, RRFS? AD II is a geat setup IMO. We sell a ton of them at the shop and haven't really seen any failures. I think it's a matter of how it is installed. We put a fuel sump on just about every truck we install the AD on. Has there been failures with AD yes, but all brands will have some failures. IMO this is the most reliable setup for both filtration and fuel supply in one package.
They also say that 1/4 and below tank fuel draw problems may come from larger or poorly installed pickup tube especially when devoid of a transfer pump. Some OEM plastic pickup screens may dislodge/break from sloshing or degradation (mostly on older units) which raises the draw a few inches from the original pickup level. Like stated above. I install a fuel sump on just about every truck that's getting an aftermarket pump. This eliminates the 1/4 issue. That's what I've run on my truck for 3 years or so now with no issues.
*Buyer Beware:
Thanks again.
To go a step more on the issue of a RR. I don't think you really understand how it works. RR system doesn't add any fuel volume. It takes the plugs out of the back of the head, and runs a line from them into a regulater. Thus eliminating the OEM dead head system. The regulater has an adjustment to adjust how much return you are allowing back the tank. Thus rasing Fuel pressure by not allowing as much fuel to return back to the tank. When you think about this you can see that with or without a RR you can't increase the output of your stock pump, as far as what size injectors/tuning it can handle. With agressive tuning or bigger injectors your demanding much more volume than the OEM pump can supply. So in this since a RR with not help you at all. When the pump can't supply enough volume to feed the demand of the tuning/injectors the pressure will fall. The regulater in the RR can't add volume. It only restricks the amount of retun going back to the tank. So when volume is low and can't reach the PSI the regulater is set at then you just get a lower pressure with no return going back to the tank. As stated above anything under 45 PSI can damage the injectors. Hope that all makes since. I have a hard time explaing this stuff sometimes.
Last edited by texans; May 14, 2013 at 07:07 PM. Reason: spelling....stupid Iphone
Maybe there is a large degree of performance variability in the OEM pumps - maybe depends on year model????
As far as 155's go, I have seen that discussed before - just need to find it ................
Scotty,
Most excellent of you to explain RRFS. Past diesel wrenching was on my JD-440A log skidder and B-Model Mack heating oil tanker to log truck conversion back in the '80's. I have tapped my gasser turbo bikes' FPRs for adjustability and understood their sealed high pressure return systems (Bosch DFI). Your 6.0l RRFS briefing was concise & helped me out. No firsthand 6.0l impressions as I'm at the mercy of a mechanic. My tools and shop are @ my cabin waaay north or I'd've dove in meself. Mom needs me, so I've bitten the bullet of another working on my machine. Nothing more painful! I'm so tired that I'm liable to key anything. I regularly lose my 1st 2 posts due to time-out even though I am signed in. It tells me I'm not signed in. Poof, all gone. I try to routinely copy while writing these novels. 8^) No publisher interest thus far. Got to laugh at myself.
If I install the OEM pump, do you fellas believe that it'll run well enough for a 6 mile drive home barring any worksmanship issues. It'll be under mild throttle without tunes on stock strategy parameters. I hope to get it back and finish with an adequate pump and Titan tank? He's had it for 8 months and the motor is awaiting RRFS system due Friday before going in the hole.
In response to BlownChevy's reply;
"I have pretty much same set up, my sticks are Casserly 155s and it won't support mine. Under hard acceleration falls on its face."
I should've typed; A2) Was the OEM pump weakness while feeding 155cc injectors with a regulated return installed?
Applied: 175/30% sticks, Driven's regulate return, powermax, BD boots/clamps, A-1 studs pinching oem, AFE stage II intake + dif cvrs, catless magnaflow, egr 86, fresh 5r110w + transgo-sk kit, Precission Industries TC, SG II, Bilstein remote reservoir + steer dampener, ELC EC-1, OEM ~ all upgrades. [Edge Insight & SCT-X3 to be installed].
I was intent on AD II upgrades to 75 relay + 8g wiring while adding a transfer pump but seal issues remain.The new AD II-165 is shelved unless I scale a wall of proven victim discontentment.
I slept well while convinced that the concept of oem pump employment for my setup was a safe solution. Reading that it would/may reliably sub-190's under aggressive tuning gave me wiggle room with 175's.
Jeopardizing new sticks is inconceivable, so rolling the dice is ...
Many obscure variables unique to each truck, builder and tuner can be responsible for success/failure regarding oem and aftermarket pump suitability and longevity. Filtration maintenance, ficm output, valvetrain, regulated return, regulator adjustment, real-time operation fuel psi readings, stick condition, etc 'may or not' be implicated.
A oem or aftermarket pump choice is innevitable yet difficult.
OEM pump employment requires live fuel pressure monitoring for damage prevention.
Does the 2006 6.0l electronic management system utilize a 'low fuel pressure fail-safe shutdown' to prevent injector damage?
If yes; What psi level is the setting?
I've read that pressures above 70 may damage injector o-rings.
What injector component succumbs to low fuel pressure?
Is low pressure pulsing or air the stick damaging ingredient @ low psi?
Is it true that the SG II cannot monitor fuel pressure?
* Please read page 2 ~ paragraph 4 through the 'Important Point" in linked PDF below?
Opinions please?
Mark,
Thanks for the reply.
Do I recall reading that you have a FICM upgrade?
What voltage is ideal as I had read that the extremes can cause damage?
What influence may this have on overall performance over stock in consideration of my upgrades and injector durabilty, if any?
Who is best for the FICM upgrade?
What recommended voltage and cost?
All the best folks.
Last edited by blownchevy; May 15, 2013 at 06:17 AM. Reason: Left out a point about RR system
