6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
TMPS interchangable?
Old Apr 22, 2013 | 03:25 PM
countryboy73703's Avatar
countryboy73703
for the guys with aftermarket wheels, when you got them, were you able to move your TMPS sensor over to the new wheels, if so what was required to do so? tried researching this but didn't have much luck. thanks
Old Apr 22, 2013 | 07:47 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
99% of the aftermarket wheels out there will let you swap your TPMS sensors over. if you have band sensors, then you can get new bands, take the sensor off the OEM wheels and put the new bands and sensor on the new wheels. if you have the rubber, snap-in sensors then you will need new valve stems. just unscrew the sensor from the old stem, put sensor on new stem, pull stem/sensor threw the hole in the new wheel.
Old Apr 22, 2013 | 08:24 PM
countryboy73703
Sounds simple enough.. Thanks..
Old Apr 22, 2013 | 09:48 PM
ATX F250's Avatar
ATX F250
When I went with Fuel wheels, they could not use the OEM bands, had to switch to the valve type. Not a big deal.
tom338
2015 - 2020 F150
Jun 1, 2018 05:01 PM
Damifiknow
2015 - 2020 F150
Jan 20, 2017 08:27 AM
BlueOvalJunkie11
Jul 7, 2013 03:28 PM
Dude Lebowski
2009 - 2014 F150
31
Nov 20, 2012 08:00 PM
Harley Guy
May 13, 2010 06:01 AM
