Sponsored by: Real Truck
Tire load range
Old Apr 22, 2013 | 06:06 AM
Buck268's Avatar
Buck268
Tire load range
I know these trucks came stock with load range "E" tires but is there any reason not to go with a load range "D" in some cases? I do no trailering, no heavy towing or hauling (although I'd like to if the need arose) and virtually all of my use is commuting on the highway. The reason for thinking about this, if you look at the BFG A/T's the load raneg "D" is severe weather rated while the load range "E" is not. Would I be introducing any real risk or sacrificing any real durability by going with the D's? Maybe gain a little better ride quality too?
Old Apr 22, 2013 | 07:12 AM
Tom's Avatar
Tom
There isn't really a safety concern as long as you don't exceed the load capacity of the tire. Most LR D tires I've found have a maximum load of 3,000 lbs at 65 PSI, which means they are safe on your truck. I don't think you'll notice any improvement in ride quality though.
I would stick with the LR E tires. You will have a small increase in stability and a much larger selection of tires to choose from.
Old Apr 23, 2013 | 08:44 PM
5.4f250sd's Avatar
5.4f250sd
I run load range d's without a hitch! I have had over 2 tons in my bed without fail. My tires are a little over sized so the load rating is the same as stock load range E tires......cheers!
KubotaOrange76
May 2, 2017 05:56 AM
dhoff024
2015 - 2020 F150
Jan 12, 2017 07:59 PM
clevelandtundra
Jun 26, 2013 04:46 PM
Hollywood703
Feb 22, 2010 11:26 AM
stupidjet
Feb 8, 2005 10:41 AM
