Compression gage
Old Apr 24, 2013 | 11:50 PM
joshofalltrades's Avatar
joshofalltrades
i hope you rotated the engine during your test - its possible that you were on the intake stroke during the test, with that valve wide open.
if thats not your story, then either your valves are junk or something is preventing them from closing. with the valve cover off you can see if they're closing as far as the valves around them
Old Apr 27, 2013 | 09:58 AM
Chevy_Eater's Avatar
Chevy_Eater
Yep, I suspect those two valves aren't closing all the way, the rockers on them are not quite as snug as the others.
Odd that whatever happened to them happened to two adjoining cylinders.
Hopefully have the time next week to pull the heads and see just what is going on.
Old Apr 27, 2013 | 12:11 PM
bashby's Avatar
bashby
Take the rockers off that cylinder if you are not sure if the valves are closed.
lawrencer12
Jul 26, 2018 01:41 PM
pamudder883
Mar 13, 2018 09:03 PM
alstieg
Oct 31, 2009 04:29 PM
Hiflyer746
Jun 25, 2008 08:58 AM
archangel
Dec 2, 2007 05:55 AM
