First f 150
Old Apr 21, 2013 | 05:15 AM
shaunbecker86's Avatar
shaunbecker86
First f 150
Im going to look at a 1994 f150 with a 302 4x4. Is there things I should be looking for other then the basics when buying a used truck? Will Be my first f150.
Old Apr 21, 2013 | 07:59 AM
subford's Avatar
subford
I take my code reader and my scanner with me and check all of the codes (KOEO, CM, KOER) and would also do a engine balance test while it is still on the lot before I would drive it off the lot. Then I would run the scanner on it and see what all the sensor values are, but that is just me.
Old Apr 21, 2013 | 08:16 AM
shaunbecker86
The scanner is a great idea. My thing is not knowing much about the motor worries me any insites on common problems with them
Old Apr 21, 2013 | 09:14 AM
subford's Avatar
subford
The one I have had low oil pressure and bad rear end bearings when I bough it. I pulled the engine and put new main and connecting rod and rear end bearing in it and it has been running great after I did that. I also replaced the timing chain & water pump while I was at it.
Curtis McCarty
Feb 28, 2018 03:56 AM
eduhat
Oct 28, 2015 03:00 PM
mugsy
Oct 29, 2004 03:25 PM
UglyTruck
Jul 25, 2004 02:12 PM
pmac57
Aerostar
Dec 7, 2003 12:10 PM
