ID this engine
Old Apr 21, 2013 | 12:24 AM
los80f100's Avatar
los80f100
ID this engine
can any one id this engine sorry for the bad pic but radiator hose goes to intake manifold and theres only six bolts to tie down the valve cover
Old Apr 21, 2013 | 12:25 AM
los80f100's Avatar
los80f100
man i failed i cant figuer out how to add a pic any help ?
Old Apr 21, 2013 | 12:31 AM
dohc_chump's Avatar
dohc_chump
This space for rent...
You can use flickr.com or photobucket.com to host your pics. I use flickr myself.
Old Apr 21, 2013 | 02:35 AM
ctubutis's Avatar
ctubutis
That stuff you have between the IMG tags takes me to a login page asking for credentials, that's not gonna work. Need the URL to the IMAGE file itself, not to a Web page displaying it.
Old Apr 21, 2013 | 06:44 AM
parkerparkerm's Avatar
parkerparkerm
six bolts would be 351w or 302, or FE if it was swapped but ive really never heard of that.
Old Apr 21, 2013 | 09:09 PM
1983F1503004x4's Avatar
1983F1503004x4
FE have been swapped into this generation of trucks. It's not worth it, as the 351M and 400's were designed to replace the 352's, 360's and 390's.
But yes, 6 bolts on a V8 is a 351 Windsor or a 302.
To tell if it's either a 351 or a 302, look at the distance between the water pump boss and the cylinder head. If the deck of the block goes about 1'' further from the water pump boss, then the head, it's a 351W. If the water pump boss is right up next to the cylinder head, it's a 302.
Old Apr 23, 2013 | 08:25 PM
los80f100's Avatar
los80f100
how about now ?
Last edited by ctubutis; Apr 24, 2013 at 11:23 AM. Reason: Fixed image display - double occurrence of http
Old Apr 23, 2013 | 08:27 PM
los80f100's Avatar
los80f100
nope still fail sorry guys ill figure this out and yes it was a swap
Old Apr 23, 2013 | 08:30 PM
los80f100's Avatar
los80f100
http://farm9.staticflickr.com/8528/8...918b3b52_m.jpg
ok i got it but its a crappy pic let me see if i can get a better one
Old Apr 23, 2013 | 08:45 PM
los80f100's Avatar
los80f100
Here's two more pics guys. I really need help finding what this engine is. I wanna start working on it but i don't have a clue what engine to ask for parts for. Sorry about the quality there phone pics
and heres my truck it doesn't look like much for now but soon it might look a little different
Last edited by ctubutis; Apr 24, 2013 at 11:25 AM. Reason: Fixed image display - change URL to IMG
Old Apr 24, 2013 | 06:15 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You need to use the 'share' button above the picture in Flickr, then select 'BBCode' option, then copy & paste that string into your post.
No need to use the advanced window.
The tiny thumbnails I'm seeing are not clear enough to tell how much the block stands above the water pump.
Look just to the inside of the power steering reservoir neck.
If the engine is original to the truck, you should be able to use the VIN or the Emissions label on the radiator support to ID your engine.
Old Apr 24, 2013 | 07:32 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I agree with Jim, the pictures are way too small to tell anything. It is a Windsor style engine, which covers 221, 260, 289, 302 and 351W. The 351 will be taller as was mentioned earlier, it also has two ribs behind the water pump. The 302 and smaller engines lack these and the heads come down almost to the water pump.
Old Apr 24, 2013 | 07:36 AM
parkerparkerm
Looks like an FE actually, can't really tell but it seems like the manifold is under the edge of the head/valve cover.
And to whoever said FEs are inferior to 351/302s...
You make think they are inferior, yes they are normally more expensive to build but I would take an FE and anysize over a 351/302 in struck stock for stock. My grandpa lives and breaths FEs so that's why I feel they are better for the purpose than a typical SBF. Not trying to salutary an argument as it is all 90% opinion
Old Apr 24, 2013 | 08:24 AM
85lebaront2
I had a 390 in my '77 F-150. It was actually cheaper to build than a 350 Chevy.
No way is that an FE, look at the bypass hose, no FE I've ever seen had an L shaped bypass.
Last edited by 85lebaront2; Apr 24, 2013 at 08:26 AM. Reason: Additional words added.
Old Apr 24, 2013 | 08:31 AM
parkerparkerm
FEs haven't been made since 76, when did you build it? And I was truly only looking at the manifold and nothing else but the whole iPhone 3 safari looking at an already crappy photo I basically only see colors lol
