AC doesn't work on MAX!!!
Old Jul 8, 2002 | 12:56 PM
John7894's Avatar
John7894
Guys,
My AC doesn't blow any harder on the max setting like it should. Also, when it's on max and I accelerate moderately the air starts to blow out of the defrost vents, if I lift it then blows out of the defrost vents then the floor then the dash like it should.
Any ideas?? I know it's vacuum related. Is the selector switch in the dash a vacuum switch or electric? Is there anything under the hood specific? Or should I just start tracing vacuum hoses?
Any help is appreciated.
John
Old Jul 8, 2002 | 07:44 PM
topo4u2's Avatar
topo4u2
Hi John, I'm just guessing but you may have a couple of problems. One is the fact that maybe your blower resistor may be bad causing your lower speed on max. When you switch to max there is a bypass that puts a full 12 volts to the blower fan.
Yes a vacuum problem is a possibility, try checking for a line off under the hood, this has been a common fault that I have seen.
If all this fails, you may have to dig deeper to find the problem...let us know how you make out.
Old Jul 8, 2002 | 11:13 PM
beratte's Avatar
beratte
Check your vacuum line to the recirc vac motor which is located on the passenger side of the engine compartment up against the firewall. It's usually a white pvc vacuum line. you can check it with a hand held vac tester/brake bleeder. That line runs to a connector located at the very bottom of the dash right over the center of the tranny hump- easy to get to. Disconnect that connector (there will be 5 lines) and plug one end of the white line and test it. Also check the vac motor with the tester and make sure it holds a vacuum. If that's not it, check the other lines and especially your vac canister.
Old Jul 9, 2002 | 09:00 AM
rgb7's Avatar
rgb7
Had the exact same problem on my '94 XLT.., the line leading to the vac motor had deteriorated. I was able to cut out the bad section & replace it with some chainsaw fuel line. Works like new now.
Good luck.
Old Jul 9, 2002 | 01:14 PM
John7894's Avatar
John7894
Thanks guys, I'll check this weekend and let you guys know. I gotta change the MLPS on the tranny this weekend as well.
John
Old Jul 10, 2002 | 08:30 AM
geo_bar's Avatar
geo_bar
A couple of months ago, my fan only ran on low and high. There is a resistor block with about five wires going to it that protrudes into the air plenum under the hood. The resistor block can be removed with one screw. On my truck, most of the terminals at the connector were badly corroded. A complete fix was made by sanding and cleaning the contacts. It is a bit easier if you remove the resistor block.
Old Jul 29, 2002 | 06:34 AM
Chinookman's Avatar
Chinookman
>Guys,
>John
So, John what did you find out? After surfing here for a while I see that others encountered the same issues I just did. Mine is a 93 F-150 5.0 4x4 and it does the exact same thing. Wish I had found this site but already converted from R-12 to 134a ahh oh well...hey thanks John for your reply......Chinookman
Old Jul 29, 2002 | 12:19 PM
Chinookman's Avatar
Chinookman
yeah-wohoo! cold air again...yeah got burned for converting to R-134a & feel silly for listening to local wrench but ....that's life...a 5 inch piece of ty-gon tubing spliced in the outside air vacuum motor now works and the A/C is back to normal.....I like this site! lotsa good info.......Now to chill once the dash is back together..hmmmm..where these extra screws go.....;-)
Old Jul 29, 2002 | 08:04 PM
92lightning's Avatar
92lightning
What tipe of tubing is the best.I had My Fuel Modulater go bad and pump fuel through all of My vaccume system.
Old Jul 29, 2002 | 09:55 PM
Brian460's Avatar
Brian460
Landon Thornton
Jun 30, 2017 04:47 AM
gogojuice
Aug 7, 2016 04:53 PM
G550_Capt
Jul 14, 2011 05:27 PM
Mr Dave73
1997 - 2003 F150
Nov 27, 2010 01:41 PM
Bronco330022
1978 - 1996 Big Bronco
Mar 13, 2003 03:38 PM
