throttle problem...I think
Old Jul 24, 2002 | 06:21 PM
slapshotjn's Avatar
slapshotjn
When I have the gas pedal in I guess the cruise position my truck acts like it's running out of gas but if I step on the pedal it accelerates w/ no problem. Recently when this happens the engine light comes on for about 10 seconds then turns off. Is this like a sensor problem or something? Any Ideas?
Old Jul 25, 2002 | 08:12 AM
michaelskerrett's Avatar
michaelskerrett
Post throttle problem...I think
Hey Slapshot, this question is like being asked what does 12 X __ = ? Not enough information. What kind of truck? what year? engine? transmission? Please try to describe what is happening in more detail and we will be glad to suggest a solution.
Old Jul 25, 2002 | 09:14 AM
edmichaels's Avatar
edmichaels
Sounds like it could be your TPS, throttle position sensor, or your throttle body. You basically have a big resistor and as you change your throttle position, it contacts along that resistor and varies the voltage. Anyway, the part where you run the most can get worn out and you have probably created an open circuit in that area so when your throttle is there, no voltage gets back to the ecm so it thinks it should be at idle and cuts the fuel down. As the other guy said, you didn't provide enough info about your engine to know what type of fuel system and throttle system you have. Hope this helps.
Old Jul 25, 2002 | 05:31 PM
slapshotjn's Avatar
slapshotjn
[updated:LAST EDITED ON 25-Jul-02 AT 09:00 PM (EST)]sorry, Its 92 F150 w/ I6 and I believe E4OD tranny. I have Dual tanks front one doesn't work.
Old Jul 26, 2002 | 01:18 PM
michaelskerrett
Slapshot, try running the truck at the same speed without the cruise control engaged (cruise control is like an auto-throttle for surface vehicles). If it's the TPS the problem should occur at the same spot on the sensor whether the cruise control is on or off. Be very steady with your foot as the bad spot on the TPS may be small. The TPS is easy to replace (2 screws and an electrical connector after you get the throttle body off the engine) and will cost about $35.
If it doesn't act the same your trouble may be your cruise control servo. There is a vacuum line (among other things) connected to the servo that you could check for leaks. The servo is located on the driver side on the engine compartment right under the hood counterbalance spring and on the wheel well side of the brake master cylinder.
Old Jul 26, 2002 | 08:27 PM
RBrendel's Avatar
RBrendel
Old Jul 28, 2002 | 01:59 PM
cdbreez's Avatar
cdbreez
I'm trying to decide if I can replace the TPS on my '92 F150, 302. Am I right in thinking that after I remove the 4 main bolts and the bracket that attaches the throttle to the manifold, and plug a coolant line, I'll have enough slack to replace the TPS?
Thanks, Chuck
Old Jul 29, 2002 | 12:43 PM
michaelskerrett
You will need to disconnect the throttle linkages and idle air control sensor too. The clips on the linkages make that part easy and the connector for the IAC is the same as on all the others under the hood. Don't forget to clean the IAC while you have the throttle body off your engine. Also look inside the manifold and ensure that the EGR return openings are clear. I have the shop-vac running while tinkering around in this area so any dislodged pieces come out the intake instead of into the engine.
Old Jul 29, 2002 | 12:52 PM
michaelskerrett
I think I should add that the unit will now come out in your hand. This is not a real hard thing to do. Just pay attention to the details and you should be fine. It is far easier to unclip the throttle lines (one from the pedal and one from the crusie control servo) than disassemble the plate onto which they attach. Some of the pieces are plastic and may be brittle due to age so some care should be taken. Remember the gaskets too. Air leaks in this area cause very high ideling so get replacement gaskets and good quality RTV or permatex form-a-gasket for the reassemble. This really shouldn't take more than 45-60 minutes including cleaning the IAC and EGR return. The good news is that no special tools are required.
Old Jul 29, 2002 | 02:33 PM
cdbreez's Avatar
cdbreez
Thanks for the info. I'm looking for a gasket now. Do I need to use sealer on the gasket?
Chuck
Old Jul 29, 2002 | 08:35 PM
slapshotjn's Avatar
slapshotjn
Okay, I replaced the sensor. The truck still acts the same! Any other ideas?
Old Jul 29, 2002 | 10:15 PM
pross's Avatar
pross
you said the engine lite came on for a few seconds...have the codes pulled.....could be one of several possible things....
