1978 - 1996 Big Bronco
MAX AC Problem 1994 Bronco
Old Mar 12, 2003 | 05:31 PM
Bronco330022's Avatar
Bronco330022
When I run the a/c in my 94 Bronco on max, it will blow out of the vents for 1-2 minutes, then it starts blowing out of the defrost ducts. I can turn the a/c to normal & then back to max & it works for about another 1-2 minutes before going to defrost. Normal a/c works fine, as does everything else (vent, floor, mix, defrost - in both warm & cool). Any ideas? Could it be vacuum related?
Old Mar 12, 2003 | 10:36 PM
msuforeman's Avatar
msuforeman
Yes you have a vacuum problem. Check your vacuum lines and I would bet a bill that one has come a lose. Easy fix just follow some of the lines till you find the culprit.
Brian
Old Mar 13, 2003 | 03:38 PM
alanscott's Avatar
alanscott
When there is a vacuum leak, the system defaults to defrost, so a leak would be my first place to look.
1993 ford
Sep 7, 2017 09:26 AM
steveamann
15
Aug 1, 2017 10:53 AM
Jim40216
Jul 13, 2017 03:04 PM
pcdocta
43
Mar 19, 2017 04:16 PM
pete315
Jun 8, 2010 07:42 AM
