Boost Gauge Interpetation
Old Apr 22, 2013 | 06:42 AM
hydro man 17's Avatar
hydro man 17
Yes, a clogged air filter or insufficient capacity of the intake to move air ( read throttle plate ) creates a pressure differential between atmospheric pressure and the intake manifold. Lower "pressure" in the intake manifold in a diesel = no bueno
Old Apr 22, 2013 | 07:38 AM
koski19's Avatar
koski19
[QUOTE=Tugly;13088578]That fits with what I was thinking. An external boost gauge is free from the bondage of the rules of the Ford MAP sensor. The turbo blows air at idle, but I don't know if it's as much as the engine sucks. A restricted air filter could further reduce the turbo's ability to supply air so low on the turbo's operation envelope.[/QUOTE)
I installed a new 6673 filter about 3 months ago about 2,000 miles. I'm using one Pete's covers. Could this cover be causing the restriction? I guess I should remove it and see if the readings change. Should I then drill and tap the spider to get my reading for boost there?
Jeff
Old Apr 22, 2013 | 08:04 AM
mueckster's Avatar
mueckster
[QUOTE=koski19;13088747]
Jeff
I am thinking of taking this one step further and removing my air filter see if the reading changes. I have a good feeling it won't and the negative reading is more likely to follow Cody's explanation of how the calculation is made.
Old Apr 22, 2013 | 11:00 AM
Tugly's Avatar
Tugly
[quote=mueckster;13088804]
I can't disagree with this, as I'm spit-balling here.
koski19 - that cover idea would be a good test. As for the installation of the boost sensor on the spider - that is ideal when tuning and modding. When you up the performance, you can eventually crowd the limits of the turbo and you want to know when you're there. Stock turbo and sticks (sensor on spider):
Old Apr 22, 2013 | 03:10 PM
koski19's Avatar
koski19
[QUOTE=Tugly;13089201]
I'll try that tomorrow and then drill and tap the spider. I need to remove the turbo for pedestal leak. I'm unable to post photos..not allowed to. Thanks for your help.
Jeff
Old Apr 27, 2013 | 10:16 AM
mueckster's Avatar
mueckster
I took a couple of videos of my Aeroforce Interceptor gauge while reading the boost at idle, with and without the air filter in place.
Boost Reading @ Idle (filter In Place) Video by mueckster | Photobucket
Boost Reading @ Idle (filter Removed) Video by mueckster | Photobucket
I have the AFE Stage 2 Filter with Pete's Cover (in my signature). No real difference at all between the two.
FordOwnerJoey
Nov 17, 2013 09:55 AM
XBAJBUSX
Feb 23, 2010 06:08 PM
1957F100
Jun 24, 2009 12:27 AM
lifted77f250
Oct 15, 2008 02:39 PM
Mizzou
Jun 19, 2003 12:13 AM
