Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
c series vin decode help
Old Apr 19, 2013 | 11:02 PM
cornwelltoolman's Avatar
cornwelltoolman
hi all just got a 1986 c7000
Need help with vin decode
1FDPD74N7GVA14889
WB. TYPE. BODY. TRANS. AXLE
175 D742A. A8. JSN. FSN
d7428da
Old Apr 19, 2013 | 11:06 PM
cornwelltoolman
Sorry i dont know why it putt that smiley in
Old Apr 20, 2013 | 01:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1FDPD74N7GVA14889
175 / D742 / ? = 8DA. A8. JSN. FSN
When 8D is typed together, that smilie face appears...unless you disable smilies in text by scrolling down to bottom of page.
1FD = FoMoCo USA incomplete vehicle.
P = Class 7, Hydraulic Brakes, 26,000-33,000 lbs. GVWR
D74 = C700 Diesel non sleeper cab.
N = Detroit 8.2L Diesel.
7 = Check digit, FoMoCo use only.
G = 1986.
V = Kentucky Truck Assembly Plant.
A14889 = 1986 Numerical Sequence of Assembly.
175" Wheelbase.
Type GVWR: D742 = C700 Diesel, 26,000 lbs. GVWR
Codes after 'Type' are mixed up.
Old Apr 20, 2013 | 03:33 PM
cornwelltoolman
Thanks the numbers kind of run together I think it is
Body aa8
Trans jsn
Axle fsn
Old Jul 27, 2018 | 09:44 PM
Ken Randles's Avatar
Ken Randles
VIN Decoding
When is typed together, that smilie face appears...unless you disable smilies in text by scrolling down to bottom of page.
G = 1986.
175" Wheelbase.
I too just picked up a 85 C7000 and was hoping you could help decode my VIN 1FDWD74N5FVA61297
Old Jul 28, 2018 | 03:22 PM
NumberDummy
Originally Posted by Ken Randles
I too just picked up a 85 C7000 and was hoping you could help decode my VIN: 1FDWD74N5FVA61297
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
W = Class 6 Air Brakes - 19,501-26,000 lbs. Gross Vehicle Weight Rating range.
D74 = C700 Diesel (non sleeper) C7000 is a C700 w/a diesel.
N = Detroit model DDA 990N or 990T 8.2L (501 cid) 8 Cylinder Diesel.
5 = Check digit, FoMoCo use only.
F = 1985.
A61297 = 1985 Numerical Sequence of Assembly, the trucks specific serial number.
Old Aug 7, 2018 | 09:55 AM
Ken Randles
Replacement seals and installer tool
F = 1985.
I finding it hard to locate replacement seals / gaskets for the 8.2l diesel in my truck, as well as the install tool for the rear main seal. Any help would be greatly appreciated.
Old Aug 7, 2018 | 11:02 AM
Destroked 450's Avatar
Destroked 450
Google: gaskets and seal for 8.2 Detroit diesel, you get pages of hits.
flaboy63
Large Truck
Apr 24, 2014 08:02 AM
Lad4811
Large Truck
Aug 4, 2012 06:13 PM
Pickupmanx2
15
Mar 31, 2012 09:18 PM
RawIron81
Feb 16, 2012 10:14 PM
jowilker
May 20, 2000 01:10 PM
