could you answer my question?
Old Apr 19, 2013 | 08:04 PM
fordboy300's Avatar
fordboy300
Tomorrow my brother in law and me are gonna be installing a MSD 6AL box into my pickup, asked a tech on MSD website that if i would have to use the duraspark box for the temp and oil gauges and he said yes because there run off the DS2 box, so how is this gonna work using both boxes im assuming the tach is run off the box as well.
thanks in adavance
Old Apr 19, 2013 | 08:09 PM
first today's Avatar
first today
Send this member TheKirbyMan a pm or he may chime in. He recently installed an MSD on his truck.
Old Apr 19, 2013 | 08:34 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
The Duraspark has nothing to do with any gauge other than the tachometer.
Old Apr 19, 2013 | 08:42 PM
first today
I believe Kirby hooked the tach wire to his MSD and it worked correctly. Can not remember fully on that though.
Old Apr 20, 2013 | 12:28 PM
Skoiv's Avatar
Skoiv
The MSD box should have a female connection that a spade fitting will fit in for a tach signal. I used it on the one I had but it was a non stock, stand alone tach. BTW... I tore out my MSD set up that ran off the DS2 box. The PO had some bad electrical connections that were causing me fits. I went back to all stock and noticed zero performance loss and cured all my electrical problems. The MSD box and MSD coil did nothing for performance in my opinion. Waste of money.
bruno2
Feb 21, 2012 10:00 PM
Williamzooker
Oct 30, 2007 08:41 PM
shawn47905
Nov 7, 2005 08:48 PM
'78 Custom
Sep 5, 2004 10:29 PM
Scott'00Rngr
1983 - 2012 Ranger & B-Series
Sep 7, 2003 09:50 PM
