I dont know do you
Old Nov 6, 2005 | 06:26 PM
shawn47905's Avatar
shawn47905
Cool I dont know do you
400m new everything bored 60 over, balanced,ss valves, polished and ported,rv cam,scorpion roller rockers, msd etc...
went for test drive, and the tach said 5000 @ 55mph and 4000 @ 45mph that is way wrong am i right? if so what could the problem be?
thanks in advance
-shawn
Old Nov 6, 2005 | 06:43 PM
Spaznaut's Avatar
Spaznaut
Your tack set to 6cyl or 4cyl?
Is your tach the one that was with the 400M?
What msd box you runnin? Maybe a setting on it to change the number of cylinders.
Old Nov 6, 2005 | 06:47 PM
Brian S's Avatar
Brian S
It should be about half that. Some tachs have a different setting for 4, 6 or 8 cylinders. Make sure it's on 8.
Old Nov 6, 2005 | 06:48 PM
shawn47905's Avatar
shawn47905
msd offroad box
i think tach is right, just sounds like it's revin' way up
Old Nov 6, 2005 | 07:04 PM
carova_kevin's Avatar
carova_kevin
Is your tranny shifting right, You might want to check the vacuum lines coming from your transmission, that will keep it from shifting properlly sometimes
Old Nov 7, 2005 | 07:43 AM
shawn47905's Avatar
shawn47905
how much vaccume is needed to properly shift tranny? i already checked for leaks...
Old Nov 7, 2005 | 10:54 AM
Spaznaut's Avatar
Spaznaut
Your gonna have to drive it and listen for the shifts. There is a modulator on the back of the trans that a vac. hose goes to. Make sure that hose isn't crimped or blocked. You may also wanna check about changing it out and/or the modulator. But your saying that the motor sounds like its turning 5000 when the tach reads 5000? Cause 5000 rpm at highway is screaming. Had a '79 mustang that was turning 4,000 at 70mph and I'd always be half deaf when I got outta the car after a highway run. Of course no interior and a 460 w/c6 didn't help any.
Old Nov 7, 2005 | 05:08 PM
Bouts21's Avatar
Bouts21
are you in 4lo per chance?? It it's a 4x4 check you transfer case
Old Nov 7, 2005 | 05:26 PM
shawn47905's Avatar
shawn47905
locked in 4 hi.
edel. performer 400 intake if it matters
Old Nov 7, 2005 | 08:48 PM
Bouts21's Avatar
Bouts21
Sounds like the tranny may be staying in second gear, check and make sure when you put the fear selector in D, and drive that the tranny actually shifts into drive on the road. Other than that, check what Spaznaut says, modulator and vacumn hose to it. I think I read somewhere that the modulators can also be adjusted, but I'll have to check my books to be sure
