Isspro tranny guage issues
Old Apr 19, 2013 | 09:48 AM
hdman6's Avatar
hdman6
Question Isspro tranny guage issues
I have 3 guage isspro setup. Lately the tranny guage has been flakey bouncing up and down on its own. Sometimes it starts out at 130 as 0 when i start the truck up, then it goes back to normal if it hits a bump. I reset the wires going to the amplifier box and also reset the connector at the tranny sensor. I did check the ground as well. all looks good. sometimes it will be good fro a day or so then it goes back to bouncing around. Any ideas? thanks jeff
Old Apr 19, 2013 | 11:02 AM
crop harvester's Avatar
crop harvester
I would give Isspro a call if you have checked all connections.
Old Apr 19, 2013 | 01:01 PM
joeyd61's Avatar
joeyd61
I had the same thing happin with my coolant temp, In my case it ended up being the plug that goes into the sending unit..Usally, when they start bouncing around, it will be a ground issue..
shacks87
Jun 11, 2009 07:18 PM
hdman6
Apr 9, 2009 03:16 PM
mndiesel
Mar 20, 2007 10:47 PM
EpicCowlick
Jan 31, 2007 07:31 PM
FLASH 13
Apr 19, 2005 09:13 AM
