I need help
Old Apr 19, 2013 | 09:19 AM
musclecars90's Avatar
musclecars90
I need help
Well my truck left me stranded on the side of the road. It's an 04 1/2 6.0. First thing is I went to go fill it up with fuel and to the store. I got about 15 min down the road and made a left. It shifted into third and truck completely shut down. So I drifted to the side of the road. Tried starting it and nothing, won't even crank. However I did notice the glow plug light stayed on for an unusual amount of time. I tried jumping the starter, motor cranks but fuel wasn't getting to it to get it to run. Checked my fuel gauge I got 70 psi of fuel. Then I hooked up my simple actron scanner. The scanner could not detect a computer so I got my buddy to bring a spare one he had when I sold his motor. Swapped them out and still nothing. Makes me believe it's something electrical? But I could be wrong.
I'm at a complete loss. Can anybody help me?
Old Apr 19, 2013 | 09:28 AM
clevelandtundra's Avatar
clevelandtundra
Can you read the FICM voltage?
Old Apr 19, 2013 | 09:38 AM
mhoefer's Avatar
mhoefer
Open top fuel filter and have buddy put key on for a short time, does it fill up?
Battery voltage above 12?
Really need codes, but from a full reader. Might be worth to tow to Ford or have scanner for a bit?
Old Apr 19, 2013 | 09:48 AM
musclecars90
I haven't checked the voltage on the ficm since it was replaced a couple months ago. But even then if it was bad it would still sit there and try to crank same way with the fuel bowl and batteries. I would get some kind of cranking out of the motor.
Old Apr 19, 2013 | 10:12 AM
mustang_309's Avatar
mustang_309
Have you checked the fuses in the fuse box located in the engine compartment on the drivers side? And the fuses in the cab?
Old Apr 19, 2013 | 10:37 AM
musclecars90
I checked all the ones that made sense checking. the only thing I didn't check are the relays because as being on the side of the road. I didn't have my tester with me and I'm at work right now.
Old Apr 19, 2013 | 10:04 PM
04badford's Avatar
04badford
Try unplugging ICP, and see if she will start,try not to run the batteries down to far they can be a bear to jump start.
Old Apr 19, 2013 | 10:45 PM
BLADE35's Avatar
BLADE35
Sorrey I am LOST Yes Sir Easy to DO!!!!!!With Me
Whats your definition of Cranking??
Starter Engauges and Spins the Moter???That My definition of cranking
Some Folks Crank means it Turns and Starts and Runs
From the Sounds of it the truck Died FAST so maynot have any DTC Yet
Do you have any gauge to see Live Data from OBDII Port???
et_miller_87
Dec 19, 2015 01:15 PM
rollinblackcloud
15
May 18, 2013 12:38 AM
strokerspeed
64
Jul 7, 2011 08:53 AM
Dvandy21
32
Feb 21, 2011 06:16 PM
snowman84
Dec 18, 2008 12:31 PM
