Air Conditioning System Cooling when OFF
Old Apr 19, 2013 | 12:45 AM
fightlivefree's Avatar
fightlivefree
I have a 92 F150, 302 cubic inch engine. After I have been driving the truck around and pop the hood I see water condensing on the air conditioning lines on the fire wall and on the black pressure tank (not sure what this part does except it's part of the air conditioning system. It could be where the expansion valve is, I don't know for sure.) It definitely feels cooler to the touch hence the condensation.
I have the air conditioning off, but the serpentine belt turns the air conditioning system anyway. The air condition system still works when I turn it on. So is this normal?
Regards,
Larry
Old Apr 19, 2013 | 12:57 AM
kermmydog's Avatar
kermmydog
No it should only be on with the defrost or A/C on. You must have a switch not shutting the A/C off.
Craig
Old Apr 19, 2013 | 01:13 AM
fightlivefree
Defroster maybe? Puzzled...
Craig
The air condition is off, but the window defrost was on. Doesn't the window get defrosted by the heat of the engine and not the air conditioning?
Regards,
Larry
Old Apr 19, 2013 | 01:15 AM
White 97 xlt's Avatar
White 97 xlt
Regards,
Larry
No, the A/C runs in defrost mode to remove the moisture from the air,, this makes the process much faster than heat alone.
Old Apr 19, 2013 | 10:40 AM
blue924.9's Avatar
blue924.9
Regards,
Larry
is it just turning the ac pulley or is the clutch engaged and turning the compressor too?
Old Apr 20, 2013 | 12:30 AM
fightlivefree
Turning Pully or Turning Compressor
I'm not sure. How would I check if the compressor clutch was engaged? I have to look into this.
Sorry for the delay. I work nights so I sleep during the day most of the time.
Regards,
Larry
Old Apr 20, 2013 | 12:34 AM
fightlivefree
I didn't know that.
So, are you saying this is normal to have the condensation on the AC system when you have the defroster on?
I will have to see if I put the heater dial to off and AC on off too to see if I get condensation.
Regards,
Larry
Old Apr 20, 2013 | 01:24 AM
White 97 xlt
I didn't know that.
Regards,
Larry
Yes, when in defrost mode the A/C compressor runs the same as it does when in regular A/C mode..
The A/C compressor runs in defrost, Norm A/C (cool), and Max A/C modes, the compressor should not run in heat, off, or vent mode.
Old Apr 20, 2013 | 01:49 AM
fightlivefree
Thanks for the info, White 97 xlt. OK. Good to go.
Regards,
Larry
abe
Jul 4, 2007 03:15 AM
scroller bill
1978 - 1996 Big Bronco
Sep 17, 2006 09:31 AM
jniolon
30
Jan 8, 2005 01:52 AM
Mudder
Bronco II
Dec 5, 2004 08:51 AM
