03 random shutdown/ hickups
Old Apr 18, 2013 | 11:39 PM
ygoldsberry's Avatar
ygoldsberry
i have an 03 f350 6.0 every now and again if its just idleing it will just shut down but then will fire right back up and have no cel if im driving it will give me a hickup lose power for a fraction of a second then come right back on. Any ideas whats going on here. It has 183xxx on it a cai edge juice module (stays on the lowest setting most of the time) and muffler/cat delete not really sure where to start
Old Apr 19, 2013 | 12:51 AM
04badford's Avatar
04badford
Berry,check Ficm volt no less than 47.5 /48 ,whats batterie 14.amp , check separete , next alt. do you have a gauge to read live data? Hicup like stall out ( fast rpm at Idiol siten at a light) jump the truck?
Old Apr 19, 2013 | 12:54 AM
BLADE35's Avatar
BLADE35
Next time it dies dont try to restart or anything
Check the Upper Fuel bowel for fuel when it dies
scan for DTC
Remove tunner
Get a gauge to read live data at OBDII Port
I use scangaugeII they sell at autozone
Sounds like a Shorted wire
Some DTC take multiple drive cycle failures to set
Old Apr 19, 2013 | 01:01 AM
BLADE35's Avatar
BLADE35
Oh 1 more thing start Truck up let it Idel and start wiggling wires around in engine and under steering collum around fuse box
See if you can recreate problem
Old Apr 19, 2013 | 01:33 AM
04badford's Avatar
04badford
sorry forgot to Input , ICP and connection, also surge =map connection to EGR cooler
Old Apr 19, 2013 | 01:55 AM
ygoldsberry
When I say hick up mean cruising at 60 or whatever speed engine shuts down and re fires all in about a seconds time the ficm was replaced end of last year just did fuel filters yesterday will check connections in the morning
Old Apr 19, 2013 | 02:53 AM
04badford's Avatar
04badford
Berry, OEM oil and FUEL filters are best for these trucks ,no after market filters check and make sure the oil cap is OEM , DO you have a gauge to read live senser data , -like(scangaugeII or dash boss ) in like- readings in temp sensers will help us help you. remember take the readings like This
!. koeo ( key on Engine Off)+ (make note)
2. start ( low Idol)=(make note)
3. 2500 rpm _( make note)
all at warm engine temp 195 is good.
Like to know what kind of oil ur useing , most use 5w 40 synthec rottella what are you running? have you cleaned your EGR lately? are you reading HOT temps? and what coolent have you been running plus flush? sorry lots to look at but recomended
Old Apr 19, 2013 | 10:40 PM
ygoldsberry
I bought the truck end of last year haven't yet gotten a scan gauge for it I'm running amsoil and napa gold oil filter and motor craft fuel filters. Haven't cleaned the egr will look into that and my temp gauge just says hot and cold have no idea what temps I'm running if its warm out needle is in the middle cold out barely gets off cold
Old Apr 19, 2013 | 10:59 PM
04badford's Avatar
04badford
I'm not sure the napa filter would be an Issuie as long as its the same height as OEM filter, mite be some thing to look into.also the cap that has to OEM as far as your mod can you unhook it and run stock to see if that helps.as Benny has stated check the wireing harness for Chaffing lots of places to rub on ,in the tech folders theres a list of places to look make sure ficm is plugged in all three plugs
Old Apr 19, 2013 | 11:04 PM
BLADE35's Avatar
BLADE35
Sounds like you need a thermostat & EGR Valve Cleaning
The Temp Gauge SUCKS in these trucks so if it reads Cold Its REALLY COLD ECT Thermostat could be Stuck OPEN
Pretty good chance the EGR Valve is all Gooey needs cleaning if it runs Cold
You also may see a MPG Incress with new thermostat since Heat is part of whats needed for Proper/Thuro diesel fuel Combustion!!
Old Apr 20, 2013 | 02:27 PM
ygoldsberry
Yeah I thought the thermostat might be stuck open will try to change it now how do you go about cleaning the egr what all is involved just pull it off and clean it or is there more to it
Old Apr 20, 2013 | 08:15 PM
BLADE35's Avatar
BLADE35
Pull it and you can SOAK the Bottom Half in cleaner
But be careful NOT to get Liqued into the weep Holes by the gasket area or up in electronics part
I found the best way to get the EGR Valve out is too use 2 Pry bars
I use 2 like this
Use use these for work so mine have been hit by a Belt Sander to make the tips Thinner and very sharp
But use 2 and position them so that they Oppose each other and pry up evenly it will pop right out
Using only 1 prybar is way harder since when you only pry 1 side it puts the egr valve on a BIND and Pinches it in there
Maybe you can work around it with 1 IDK
2 bars work slick
SOme undo bolts and turn egr valve to where they can Loop Wire threw the bolt holes and then use Something to go threw the wire loop and pry it up
Wire trick works but bars are way slicker
radskull
94
Sep 24, 2019 01:41 PM
Steven Osuna
Nov 12, 2016 12:58 AM
Padlock
Apr 20, 2014 10:30 PM
skyline82
Jun 12, 2013 06:28 PM
1Knight
Jan 24, 2006 04:44 PM
