Sponsored by: Innova
Speaker Adapter Tip - Cutting Boards
Old Apr 18, 2013 | 10:06 PM
KCAsound's Avatar
KCAsound
Hey guys. Thought I'd post a tip for those wanting to upgrade your speakers. This is cheap and works great.
I pick these cutting boards up at Walmart for like $2.25 each.
I trace the factory 6x8 onto the board then draw my cutout for my 6 1/2.
Then I cut it out with my jigsaw or dremel. The handle is nice to hold onto for cutting.
And there you go. A great adapter for just a few bucks. No worries about moisture and it's a solid mount. Plus the screws hold great in it.
Old Apr 18, 2013 | 10:43 PM
edawgm's Avatar
edawgm
Very nice.
Old Apr 18, 2013 | 10:49 PM
KCAsound's Avatar
KCAsound
Its just something simple. I don't know how many times I have forgotten to pick up some ABS or have something to make a adapter out of when I'm installing on-site. There's always a dollar store, walmart, kmart or anything around that sells these.
Old Apr 19, 2013 | 08:07 AM
JWA's Avatar
JWA
That is a great idea---reps sent!
Old Apr 21, 2013 | 10:54 AM
Bob Landry's Avatar
Bob Landry
Just a question. Why not upgrade to the same size speakers?
Old Apr 21, 2013 | 02:55 PM
KCAsound's Avatar
KCAsound
Not all companies offer a 6x8 component speaker or also some people will argue that a 6-1/2" is better than a 6x8 due to circular cone, cone surface and whatever. I just think it's silly. I've personally listened to two identical trucks with identical radios that we had to put 6-1/2s in one and 6x8s in the other due to inventory. Three of us listened to them and non could tell difference. Infinity does happen to offer a 6x8 component but on this particular vehicle none of my distributors had them in stock at the time.
Old Apr 22, 2013 | 11:37 PM
86F150302's Avatar
86F150302
Do you have a UPC number for them? Ive seen people use cutting boards before but the only ones I could find were $9 each.. I built my adapters from birch wood but would like to try the cutting boards.
Couldn't find them on their website either.
Old Apr 24, 2013 | 05:35 PM
lariat97's Avatar
lariat97
The cutting boards are nice. I will use them when I change the speakers in my F250. I will have 2 tweeters in the stock opening & a custom pod for my 6.5s. They are too deep to go in the door
Old Apr 24, 2013 | 06:16 PM
KCAsound's Avatar
KCAsound
they don't seem to have them on their website but they are there. I just bought a couple of them here recently. I even bought a larger one at the dollar store because I needed to make a spacer for a 10 inch woofer because it was a little too big for the box. it was eight bucks but I was working on site and I need something fast
Old Apr 25, 2013 | 08:02 AM
JWA's Avatar
JWA
Those types of cutting boards should be available almost anywhere affordable home kitchen stuff is sold. Amazon comes to mind--a good place to check as a beginning if looking mostly online; eBay too.
If there's a plastic distributor near you see if they sell cut off pieces of Lexan, Plexiglas or anything else similar by the pound. Such stuff can be worked with normal woodworking tools.
I think the biggest advantage with this sort of material is its inert, not subject to any ill effect of the conditions it will see as a speaker adapter.
Still a great idea!
Old Apr 25, 2013 | 08:16 AM
Bob Landry's Avatar
Bob Landry
My local sound shop uses MDF. It's not one of my favorite materials to work with because of the toxicity of the dust and that it gets really unhappy in the event you have a water leak.
The cutting board material is a great idea and you can pick them up cheap, usually at a dollar store or Walmart.
Old Apr 28, 2013 | 09:25 PM
Jasondt2001's Avatar
Jasondt2001
This is genius!
MIKES 68 F100
21
Jan 27, 2018 03:43 PM
JWA
22
Sep 27, 2013 11:06 AM
spoolen&smoken
Feb 27, 2013 04:53 AM
PRIMERED79 SHORT BED
Mar 30, 2012 11:01 PM
Fifty-Fourd
24
May 2, 2011 10:32 AM
