Coil Buzzing
Old Apr 18, 2013 | 10:41 AM
CMcNeely's Avatar
CMcNeely
Trailering
Coil Buzzing
86 Ford Bronco 5.0
Just swapped from efi to carb. Will start and run but I get a buzzing sound from coil when I have the fuel pump on. When this happens it is continuously arcing. I have the factory fuel pumps wired in to a toggle switch with power from the battery. Tach also bounces around when this happens. I have a wire running from toggle switch to the factory plug the efi harness hooked up to for power to the pumps. Does not always happen at initial start up but seems to always begin after engine warms up. Is this a grounding issue from the conversion, an issue found in using factory high/low pressure pumps after a conversion?
Old Apr 19, 2013 | 03:11 PM
Franklin2's Avatar
Franklin2
Try running a ground from a clean place on the engine to the cab firewall(should already have one).
Old Apr 20, 2013 | 09:00 AM
CMcNeely's Avatar
CMcNeely
Trailering
AAHHH HHHAAAA!! Forgot to tighten that one after I got the carb intake put on. Finger tight doesn't quite get the job done. Problem seems to have stopped. Ran for 15-20 minutes...nothing. Thanks
sngehl01
Oct 2, 2015 01:37 PM
iwals
Jan 9, 2011 07:56 AM
Dads 66
Jan 1, 2005 08:53 AM
ford4x486
Oct 20, 2003 10:18 PM
PowerbyFord
Apr 3, 2002 10:35 AM
