Electronic locking axle
Old Apr 18, 2013 | 06:21 AM
03v10KingRanch's Avatar
03v10KingRanch
I'm wondering if someone can help me out here. I purchased a used 2011 F-350 long box crew cab 6.7 and it's 2 wheel drive. The truck has an electronic locking axle and I'm wondering would I use that (locked) when towing or just on slippery conditions?
Old Apr 18, 2013 | 06:37 AM
Hdslider's Avatar
Hdslider
Just leave traction control on. It works great. The locking ELD really is when you think you might get stuck..but it kicks out at 20 mph.and also senses the steering wheel is being turned a certain amount. I personally find it dang near worthless. One blip of the throttle and your over 20 mph.
Old Apr 18, 2013 | 07:12 AM
03v10KingRanch
Thank you, that helps allot
Old Apr 18, 2013 | 08:17 PM
azking_Ranch's Avatar
azking_Ranch
It cuts out at about 20 mph, i've used mine when the roads a slippery.
Old Apr 19, 2013 | 06:16 AM
720Deere's Avatar
720Deere
There is a plug in module available that allows you to use the ELD at any speed. I can't remember who sells it, but there have been threads about it on this forum.
Old Apr 19, 2013 | 06:50 AM
stangr8cr's Avatar
stangr8cr
SPE has the module for the ELD. I think it's $50.
Old Apr 20, 2013 | 10:29 AM
jdonovan35's Avatar
jdonovan35
I find it VERY useful. I pull heavy equipment trailers 14K-16k. I often go up gravel driveways, or into fields, and I'll spin a wheel. A quick pull of the **** and I've got enough traction to move. 4wd is a help too, but with all the pin weight over the rear axle, ELD is a bigger help.
tjgalinski
Aug 28, 2015 08:42 AM
Muddog99
Jan 1, 2014 01:14 PM
big ol 84f150
Feb 4, 2006 10:23 PM
