2x4 to 4x4
Old Dec 28, 2013 | 04:54 PM
Muddog99's Avatar
Muddog99
2x4 to 4x4
I have a 2 wheel drive f250 thats 2 wheel drive i can get a divorce tranfercase but the reat of it how do i hook up the front axle its got a stright axle front already so do any of you know what i have to do to hook up the front axle and how do i put transfercase lever in the cab
Old Dec 28, 2013 | 05:02 PM
Muddog99's Avatar
Muddog99
Oh and its a 65
Old Dec 28, 2013 | 07:19 PM
PROSTOCK's Avatar
PROSTOCK
Unless you have some oddball, you do not have one or the other, a '65 F250(or newer) or a straight front axle. '65 and up went with twin I-beam which would be really difficult to change to 4WD.
Old Dec 28, 2013 | 07:33 PM
Muddog99's Avatar
Muddog99
I head it would be difficult but i just bought it with the straight axle front and all i had heard was what you said but it has straight axle
Old Dec 29, 2013 | 06:49 AM
jowilker's Avatar
jowilker
Get down on the top of passenger side frame rail just ahead of where the axle passes under for the GO TO VIN. Digits are about 1/8" high and it starts with F. It may be hard to dig out but it is there.
Door tags can be swapped and the truck can be titled to the door tag.
guluk
John
Old Dec 29, 2013 | 08:51 AM
Shadowrider123's Avatar
Shadowrider123
Post a pic of the front axle and the door tag.
Old Dec 29, 2013 | 11:15 AM
Muddog99's Avatar
Muddog99
Jowilker are you saying the truck may not be titled right i juts bought it going to pick it up sometime between now and jan 6
Old Dec 29, 2013 | 11:41 AM
jowilker's Avatar
jowilker
I am saying that it is a possibility, starting in 65 Ford 2wd pickups got the Twin I-beams. Straight axles stopped in 64. Your 65 F250 should have Twin I-Beam.
John
Old Dec 29, 2013 | 01:42 PM
iggybob44's Avatar
iggybob44
the transfer case lever is simple........you cut a hole in the tranny tunnel. it will need to be long enough to allow full travel of the 4 positions of a Dana 24 or Np205 T-case, you should be able to get a shifter boot and all the hardware out of a junkyard donor truck....ive owned 6 F-series trucks, only 1 had totally matching VIN/doortag/powertrain/body combo.....all the others had been changed from factory original, its hardly a rare occurence
Old Dec 30, 2013 | 02:19 PM
PROSTOCK's Avatar
PROSTOCK
Originally Posted by iggybob44
...ive owned 6 F-series trucks, only 1 had totally matching VIN/doortag/powertrain/body combo.....all the others had been changed from factory original, its hardly a rare occurrence
Exactly. Mine is one of those rare occurrences, all but tailgate is (or was) original....'65 F250 twin I-beam just like the OP's should be.
Old Jan 1, 2014 | 01:14 PM
1960fordf350's Avatar
1960fordf350
It could be an F350. Still used I-beam axle on F350's in 65 and 66 single or dual tired trucks
Dobies4life
Nov 3, 2013 02:15 PM
revans9295
19
Jan 22, 2012 02:07 PM
maverickfe390
Sep 22, 2010 01:15 AM
98infinity
1997 - 2003 F150
May 11, 2007 12:20 PM
jere925
Jan 8, 2007 04:32 AM
