Sponsored by: Auxito
odd electrical connector help
Old Apr 17, 2013 | 09:49 PM
84F150XLT's Avatar
84F150XLT
i have a 98 F150 and i was under the dash this afternoon wiring up the trailer brake and i noticed an odd electrical connector. it is located between the hood and brake release and is attatched to a metal bracket. it had 2 green and black wires and 2 red and pink wires. but only 2 pins. does anyone have any ideas???
Old Apr 18, 2013 | 07:27 AM
projectSHO89's Avatar
projectSHO89
Rear differential sensor diagnostics connector for the RABS system.
Undocumented in the service manual, but a technician can make a quick resistance check across those two pins and measure the parallel resistance of the rear ABS sensor and the input circuitry of the RABS module. A reading of 1.5K or less indicates the sensor and the wiring harness is intact.
A tech could also use a scope or AC meter to monitor the output signal of the sensor for further diagnostic testing.
Old Apr 18, 2013 | 07:42 AM
84F150XLT's Avatar
84F150XLT
thats awsome thank you very much!
Rubidon
46
Oct 25, 2019 06:32 AM
09dewaed
Apr 24, 2018 06:09 PM
crouchingbillko
6.7L Power Stroke Diesel
Dec 11, 2017 06:22 PM
nebechanezer
2009 - 2014 F150
Jan 9, 2014 10:27 AM
luckild
1997 - 2003 F150
Jun 18, 2003 03:41 PM
