Egr hose leak?!
Old Apr 17, 2013 | 09:23 AM
ConvertedFord's Avatar
ConvertedFord
Egr hose leak?!
I have a sinister delete kit the small hose is leaking some is there a fix for this or a replacement part?
Old Apr 17, 2013 | 09:38 AM
npccpartsman's Avatar
npccpartsman
What kind of clamps are you using, spring or screw?
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Does sinister use the oem hose with no clamps?
amdriven2liv
Same thought here.
Old Apr 17, 2013 | 09:39 AM
npccpartsman
Originally Posted by amdriven2liv
Same thought here.
great minds think alike
Old Apr 17, 2013 | 09:40 AM
ConvertedFord
Mine came attached already. It's been on the truck about 2years. No way to tighten
Old Apr 17, 2013 | 09:44 AM
npccpartsman
So I take that to mean spring clamps???
Make sure it's the hose and not the housing leaking. The only fix I know is to remove the housing and hose, check for corrosion or splits and replace the hose. I recommend using spring clamps as they maintain tension as the hose shrinks and expands from heat and cold
Old Apr 17, 2013 | 10:04 AM
amdriven2liv
They kind of look like Screw clamps from the pictures I just looked at.
And depending on how they put those clamps on, the turbo and pedestal may need to be removed to access them. Sadly.
Old Apr 17, 2013 | 10:13 AM
npccpartsman
I bet the clamps have worked loose.
Old Apr 17, 2013 | 12:18 PM
amdriven2liv
You know, I have looked at some of these delete systems and only one used the OEM hose. (can't remember which company was doing it though)
I always had issues with those that didn't. Those clamps in that spot just doesn't make any sense to me.
Now a person "MIGHT" get lucky and get a socket under there to remove the hose, but you would play heck getting them back in.
And, you can't just slip an OEM in there to replace it.
Old Apr 17, 2013 | 05:00 PM
BLADE35's Avatar
BLADE35
The sinister kit comes with worm screw clamps the housing isnt made for this style lots of folks run them me included but I put the clamps on Further back then on the smooth spot that holds very little cause of the Tangs
here is a OEM Hose what I will be switching back to if the worm clamps leak
Sullid01
Jan 23, 2017 11:08 PM
str8sixman
Oct 17, 2016 11:30 AM
joejackF250
Oct 14, 2014 09:14 PM
Steve in NC
Sep 4, 2014 10:44 AM
scottlane
Nov 4, 2006 04:58 PM
