Egr delete hose replacement
Old Oct 16, 2016 | 05:41 PM
str8sixman's Avatar
str8sixman
Hey guys...had a coolant leak I finally traced to the rubber hose on an egr delete (previous owner installed, not sure of brand). Looks like the jackwagon who installed it cranked the clamps way too tight and they eventually split the hose. I have a piece of heater hose that looks like the right diameter and cut to size should fit fine. I guess Im just looking for some reassurance that it would be ok to use in that situation.....thanks!
Old Oct 16, 2016 | 06:03 PM
BLADE35's Avatar
BLADE35
It will suffer the same fate eventually
use the correct part you will be happier
Old Oct 16, 2016 | 06:11 PM
str8sixman's Avatar
str8sixman
do you know anywhere I could get a specific hose without having to buy a whole other delete kit?
Old Oct 17, 2016 | 11:30 AM
groy's Avatar
groy
That's pretty common replacement...if you can't from a Ford dealer I'd to NAPA....take the old one with you either way.
wedge542
Mar 17, 2016 07:20 PM
happscrap
Nov 18, 2014 10:56 PM
joejackF250
Oct 14, 2014 09:14 PM
Steve in NC
Sep 4, 2014 10:44 AM
ConvertedFord
Apr 17, 2013 05:00 PM
