bye-bye hd egr?
Old Jul 6, 2002 | 11:22 PM
richard_d's Avatar
richard_d
bye-bye hd egr?
i have an 88 f250 hd version with a 351. part of the egr system, which injects air into each cylinders exhaust port at various times, has developed an exhaust leak. rather than fix the piping i am being urged by friends and mechanics alike to eliminate the whole system including air pump. i have gutted the cat as we don't have emissions testing here and most likely won't for many years. i realize it sucks power to drive the air pump but am hesitant to rip out the whole thing. i like keeping the original- complete - look of the engine / engine compartment. any comments?
richard
88 f250 hd 4x4 extra cab,
Old Jul 8, 2002 | 02:50 PM
alanb's Avatar
alanb
bye-bye hd egr?
I had a 90 HD F250 4x4 that I removed all of the "extras" from including EGR, CAT, pump, all the fruit cans and everything. Also added headers. It did fine, but had a little rough idle from then on.
Seemed to run out a good deal better. Someone with more experience could probably have solved that.
Old Jul 30, 2002 | 11:56 AM
jim henderson's Avatar
jim henderson
bye-bye hd egr?
Old Jul 30, 2002 | 02:13 PM
Andy88fan's Avatar
Andy88fan
bye-bye hd egr?
I have also disabled the "Thermactor" system by taking out some of the plumbing just so I could make room for my Jacobs ignition box and felt I didn't need the system anyway. I still have the air pump installed because I don't know what to do about the drive belt, which leads to the question "Will the belt tensioner make up for the extra slack left by the missing pump or do I need a shorter belt"?
It does leave a code now but at least I know why and I have'nt had any other drivability problems because of it.
BTW: It would be wise to keep all original parts just in case
Andy
91 F-150 XLT SC 4x4 351W E4OD, K&N FIPK, Flowmasters, Jacobs ign.
01 Taurus SEL
Old Jul 30, 2002 | 03:44 PM
Pastmaster's Avatar
Pastmaster
bye-bye hd egr?
>case
You would need a shorter belt. I removed the entire system except for EGR on my 1989 F-150 302. I noticed a bit higher than oem idle and the "check engine" light comes on during WOT, but it's better in the long run.
'93 F-150 loaded and modified!
Check my Gallery
krooser
20
Sep 16, 2014 10:12 PM
BlueZack
Exhaust Systems
Oct 2, 2003 07:06 PM
bonzex79
Jan 11, 2003 10:14 AM
richard_d
Electrical Systems/Wiring
Nov 25, 2001 11:26 PM
