idle/fuel?? problem
Old Apr 15, 2013 | 09:58 PM
FORD-or-Die's Avatar
FORD-or-Die
idle/fuel?? problem
been having some troubles with my 94 f150 5.0 its been running real ruff at i replaced the iac it started to run better but has acceleration and occasional miss. i ran some codes and came back with this 172(runnning lean) 538(insufficiant rpm change) 632 (overdrive cancel switch)
Old Apr 16, 2013 | 07:39 AM
subford's Avatar
subford
You may have a fuel pressure problem, put a pressure gauge on it and see what you get.
Old Apr 17, 2013 | 12:21 AM
FORD-or-Die
Got low 30's?
Old Apr 19, 2013 | 05:16 PM
tbolt64's Avatar
tbolt64
Your fuel pressure should be between 30 - 34 lbs at idle.
Speaking from experience, the first place I would check when dealing with drivability problems, especially low RPM problems, would be looking for a vacuum leaks on the plastic vacuum lines coming from the vacuum tree on the intake. The leak can cause a lean code, that or thermactor tubes (on the back of the heads on a V8) being rusted out.
Old Apr 19, 2013 | 06:02 PM
FORD-or-Die
Turns out the o2 sensor was out who wouldv guessed? But now it idle's real high in park
Old Apr 19, 2013 | 06:33 PM
1993_f350_2013's Avatar
1993_f350_2013
try disconnecting the battery for half hour
ol_red92
Jul 8, 2014 03:38 PM
bighatchy
Feb 12, 2012 09:15 PM
mikefaa
Nov 10, 2011 03:32 PM
4 flat tires
Jul 8, 2011 08:06 PM
h0trod4x4
Aug 21, 2005 07:48 AM
