Ruby doesn't want to idle
Old Feb 8, 2012 | 11:19 AM
bighatchy's Avatar
bighatchy
So Ruby has decided the she doesn't want to idle very good. 73 f100 lwb 390 auto 2wd edelbrock 1406 duraspark II. The engine seems to run as usual when your driving, but if you have to stop the engine might slow to a stop. It seems to be carb/fuel related. I turned the idle up a hair but it didn't cure the problem. I changed the fuel filter as well. Do I need to tear apart the carb? Thanks in advance guys! Daryl
Old Feb 8, 2012 | 11:45 AM
earthquake68's Avatar
earthquake68
Plug in a fuel pressure gauge after the fuel pump. If you hold 5 psi, rebuild the carburetor.
Old Feb 8, 2012 | 08:29 PM
fmc400's Avatar
fmc400
MSEE
Usually fuel issues manifest themselves in the opposite way; it will idle fine (when fuel demand is low) but cut out as RPMs increase and the demand for fuel increases. Check for vacuum leaks; vacuum leaks typically show up at idle but go away as the throttle is opened (and vacuum drops naturally).
If there are no vacuum leaks, check the idle mixture using a vacuum gauge.
Old Feb 8, 2012 | 09:07 PM
earthquake68
Agreed, but a vacuum leak usually raises the idle, not chokes it out. My thought was needle and seat not sealing (still closing, but not sealing properly and allowing gas to seep through) and flooding the engine at idle. When there's more demand for fuel, it uses it instead of drowning it.
Old Feb 8, 2012 | 09:08 PM
Blue and White's Avatar
Blue and White
Besides this, I have found a can of Gumout (carb formula) can help. My dent has done this... the gumout seems to help clear it up. I know I eventually need to replace or re-build the carb but not ready yet.
Old Feb 8, 2012 | 09:13 PM
bighatchy's Avatar
bighatchy
I bought the carb on craigslist a few months ago and I at the time just put it on to see if the engine would run. It had been sitting since 2000. It wouldn't surprise me if there is dirt or something stuck somewhere
Old Feb 8, 2012 | 09:38 PM
Blue and White
PS... I understand the Edelbrock carb needs the fuel pressure regulated to 4-5 PSI. The standard 6-8 PSI from a mechanical fuel pump is too much for the Edelbrock needle/seat setup. The Holly regulator (Summit or speedshop) is supposed to be best. This could be the problem... and needs to be checked/corrected anyhow if you stay with an Edelbrock carb.
Old Feb 12, 2012 | 09:15 PM
bighatchy's Avatar
bighatchy
Well I took the carb off and opened it up. It was full of nastiness. I'm sure it could use a kit, but I just cleaned it as best possible with carb cleaner and a brush. Slapped it back on and cranked it over. Ran best its run since I got her running again.
Blue, I've heard that about edelbrock carbs needing a fuel regulator. I'm sure it wouldn't hurt, but that engine ran fine for 8 years with an edelbrock carb without one. So, I'll let that mod slide for now. Need to get some headers and redo the exhaust
Brynjaminjones
13
Feb 5, 2019 03:48 AM
DrZoom
30
Dec 15, 2015 07:11 AM
agaristo77
1978 - 1996 Big Bronco
May 8, 2012 02:35 PM
Argess
Aug 12, 2009 02:56 PM
jriley301
Dec 22, 2004 04:38 PM
