Sponsored by: Real Truck
Air conditioner :(
Old Apr 15, 2013 | 02:03 PM
jerryjerry05's Avatar
jerryjerry05
Air conditioner :(
My 99f250 Superduty.V-10
3 years ago I replaced the compressor and what ever else it needed.
It worked great for 1 year.Then no cool.The mechanic said it was low,probably had a very slow leak.
He filled it and worked great till last spring.
I added some freon and it worked great till this spring.
It's still cooling to about 68/70 Not cool enough
I thought I'd add some freon.
Not working this time?
Any ideas ??? Thanks,Jerry
Old Apr 15, 2013 | 04:10 PM
Ridenred333's Avatar
Ridenred333
Check all of your connections, one of my connections down on the lower side under the truck had come loose. Air would come on but would not cool down. Also when you just add freon you does it have oil in it. If its leaking freon out it probably leaking the oil out that keeps everything lubed.
Old Apr 15, 2013 | 04:30 PM
projectSHO89's Avatar
projectSHO89
I replaced the compressor on my 6.8 about 21 months ago. Danged thing leaked down last summer so I added some refrigerant and dye. Well, the thing is leaking where the two halves of the compressor body meets which means a defective rebuild from Four Seasons via Oreilly's. At least I have the two year warranty version, so I only need to foot the bill for all the other materials (refrigerant, accumulator, o-tube) as well as spending an afternoon replacing it....
Old Apr 15, 2013 | 06:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
Check your compressor clutch air gap.
Old Apr 16, 2013 | 06:08 AM
jerryjerry05
Thanks for the reply's.
What's a compressor clutch air gap??
Old Apr 16, 2013 | 06:13 AM
redford's Avatar
redford
Check this out:
SpringerPop's Compressor Clutch Air Gap
Old Apr 16, 2013 | 06:33 AM
projectSHO89
A three year old compressor isn't likely to have a worn out clutch.
Check the FAQs (see signature) for more ideas of what to look for.
Old Apr 16, 2013 | 08:11 AM
jerryjerry05
Yea I probably haven't put maybe 3-5K on it since the new compressor.
It just sets most of the time.
Old Apr 16, 2013 | 11:34 AM
projectSHO89
Same here. Less than 5K on this compressor.
IZZYAZ
Apr 10, 2009 10:46 PM
rob_engineer
18
Jun 2, 2008 04:25 PM
Novitsky
Sep 9, 2007 09:48 AM
woodly1069
Mar 13, 2007 06:09 PM
bigblue
Jun 28, 2002 10:44 PM
