Dog House Removal?
Old Apr 15, 2013 | 01:31 PM
BII Plow Truck's Avatar
BII Plow Truck
Dog House Removal?
I'm new to the Econoline world and recenlty picked up a 1990 E350 based class C motorhome. How does the dog house come off? I released two latches (one on each side) and it seems to be stuck. I doubt it has ever been off, for it only has 24,000 actual miles. I'm glad it's a tight fit for heat and fumes, but perhaps you gurus have some tips....I want to do a tune-up!
Old Apr 15, 2013 | 03:35 PM
95e150CW's Avatar
95e150CW
Last time you'll willingly admit that!
There should be two latches on the sides, in the foot wells, and two latches on the front lower area of the dog house. 4 latches total. I recommend unbolting and removing the front seats to make room to work. If you don't, you will be working and contorting much harder than you have to, its already a pretty crummy job to do plugs and wires on these bad boys!
Old Apr 15, 2013 | 04:18 PM
fordman75's Avatar
fordman75
The older vans don't have lower latches. They have a couple metal 90 degree brackets. These brackets are bolted to the floor. If there is carpet you may have to pull it back to find the bolts.
Old Apr 15, 2013 | 07:01 PM
Club Wagon's Avatar
Club Wagon
Yup, that's the way my '85 dog house was removed.
I've also never taken out the seats just to remove the dog house. Yes, it's a tight fit & you need to be careful about seat upholstery. However, when I tried to remove the seat bases I ran into great difficulty with rusty bolts. These 4 special bolts thread into captive nuts on the underside of the floor & the extra threads are exposed to the elements. They can be a bear to get out, even if you bathe them in penetrating oil in advance.
Old Apr 15, 2013 | 07:23 PM
fordman75's Avatar
fordman75
I'm too lazy to pull the seats out of my vans just to pull the dog house. Yes it's like wrestling an elephant at times. But I've always been able to pull them out with the seats in place.
The only reason I see to pull the seats would be to do some major engine tear down. With the seats out you've got plenty of room to lay down on the job!!
Old Apr 15, 2013 | 09:56 PM
95e150CW's Avatar
95e150CW
I pull the seats out when I do wires/plugs on my vans. It only takes about 2 minutes per seat and it makes it easier.
You do NOT need to pull the seats to get the doghouse out.
Old Apr 15, 2013 | 09:57 PM
Club Wagon's Avatar
Club Wagon
Would like to add that I've had OEM seats & suspect that certain aftermarket & conversion seats/bases may take up more real estate than FORD originals, making it more difficult to remove dog house.
As you say "some major engine tear down" work would be greatly facilitated by removing the seats/bases. However just doing plugs/wires is EZ enough w/seats in place. Did I6 cylinder head on '85 & 302 exhaust manifold on '92 w/o removing seats.
Old Apr 15, 2013 | 10:37 PM
fordman75's Avatar
fordman75
You don't need to pull the seats and bases to work on the engine. It just gives you a lot more room if you do. But like I said I'm too lazy to do that unless it's something I'm going to be spending quite a bit of time working on. I'm in Minnesota so the seat base bolts don't come out very easy!
I will also add this comment. The dog house on my 96 it much more of a pain to remove then any of my 91 & older vans are/were.
Old Apr 15, 2013 | 11:55 PM
joshofalltrades's Avatar
joshofalltrades
i left the seats in place for a complete engine rebuild in my 87, but i pull the seats out to change spark plugs in vans from around 2000.
and my seats aren't stock, so its rather challenging to wiggle the doghouse out with them in place, especially with my crap pile between them.
Old Apr 16, 2013 | 03:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I use to pull the doghouse up and out without touching the seats, but I got tired of wrestling it, and i'm a clean freak, can't stand having the seal hit the dash or door panels.
It takes 2 min to remove the passenger seat, and then the doghouse comes out no problem and you have more than enough room to work on the engine for whatever.
Save your self a hassle, at least remove the passenger seat. It's 4 bolts.
And yes, the older vans had 2 latches and 2 bolts on the floor.
Best of luck to ya, doing a tune up on that EFI 460 in a van!
Old Jan 23, 2019 | 02:46 PM
jvossman's Avatar
jvossman
Anything besides the bolts and latch. They are open, but not budging...
Old Jan 23, 2019 | 04:25 PM
85e150's Avatar
85e150
Two bolts on the floor, a latch on each side. You may be dealing with a Coke or Milkshake seal. See the prior thread about pulling the passenger seat to get more "room to dance".
Double check your bolts and latches, then apply brute force. Maybe some heat along the rubber seals to start.
Old Jan 23, 2019 | 09:48 PM
jvossman's Avatar
jvossman
Brute force did the job. Thanks 85e150!!
leevining
Aug 9, 2014 04:39 PM
jtbarker4
Feb 14, 2011 09:04 PM
Dutch123
1978 - 1996 Big Bronco
Sep 20, 2007 03:27 PM
fattmann
Dec 15, 2006 01:22 PM
Blackhorse5
1983 - 2012 Ranger & B-Series
Mar 21, 2005 03:42 PM
