Jump seat-ectomy
Check to see if any plastic trim\molding pieces need to be removed to expose bolts (I don't think there was).
Remove the bolts from the bottom of the jump seat (easy to reach)
Remove the bolts for the seat belt mechanism (harder to reach). I had to get an extension put together to reach down past the seat belt and unbolt
Once you do that, the seats should just come right out. Maybe 4 or 5 bolts total for each seat.
HTH
Thanks for the advice. I figured it might be relatively simple to remove the jump seats. I just don't want to damage anything. I'll give it a whirl and post the results in a few days. By the way, how do you like your Gibson exhaust system? One or two outlets?
