Trucks with flatbeds
Old Apr 15, 2013 | 09:11 AM
joegeds's Avatar
joegeds
I see a lot of these trucks with flatbeds on them and wonder if a box of the same year/make/model is interchangeable. I mean, assuming I can find a box, is it as easy as taking off the flatbed and putting the box on? here is an example of the flatbeds I see quite a bit:
Ford : F-250 XLT RANGER in Ford | eBay Motors
Old Apr 15, 2013 | 09:30 AM
parkerparkerm's Avatar
parkerparkerm
I'm pretty sure you can make any dentside bed fit on the truck with little to no modification
Old Apr 15, 2013 | 10:27 AM
redroad's Avatar
redroad
The highboy because of frame width will have mounting holes in a different location than any of the other standard wheel base beds .. What is odd about the ebay add is the seller mentions a behind the seat OEM gas tank .. The 1979 F250 never came with such a gas tank
Old Apr 15, 2013 | 10:28 PM
privateer, eh's Avatar
privateer, eh
Flat decks and dump boxes are built on a set of rails and have a wooden bumper strip between the deck rails and truck frame. They are attached together with at least 4 pieces of plate steel usually some times 6. I say usually due to the fact that I've seen people use plywood and metal band strapping. You should be able to mount a fendered truck box using 3 or 4" angle stock. What you use depends on how much your frame dips.
troymn
Nov 4, 2017 07:16 PM
candoo
Apr 14, 2015 09:15 PM
GQROD
17
Feb 6, 2010 01:53 PM
flyhound
Dec 26, 2004 01:22 AM
Sedric
Jul 31, 2002 06:23 AM
