Modular V10 (6.8l)
2001 Ford
Old Apr 15, 2013 | 12:11 AM
Just passin through.'s Avatar
2001 Ford
It's an F-350 4X4 5 spd V-10.
My fuel pump gave up the ghost so I had my neighbor pull the tank for me and get out the old fuel pump readying for a replacement.
Here's the problem, When he took the top of the tank lid off he cut the fuel lines at the connection, then when he realized he screwed up he completey threw the connection away... OK, I screwed up letting someone else do it!
Now I have the new fuel pump in, I bought a Haynes manual to help identify the wires that go together. It doesn't show the fuel tank gauge wires nor the Fuel pump wires. I've done a search here and other places on the web. It's like they want to keep it secret? lol
Would anyone have the wiring diagram for the fuel pump and Gauge sender wiring? I'd be happy to buy it from someone. None of the wires inside that tank compared to the wires outside of the tank match.
Thanks in advance all. I appreciate any help or advise. Ron
Old Apr 15, 2013 | 03:28 PM
handifletch's Avatar
handifletch
He cut the fuel lines or the electrical connection wires?
Old Apr 15, 2013 | 03:32 PM
Ridenred333's Avatar
Ridenred333
Does the Haynes manual you bought have the wiring scamatic in the back?
Old Apr 15, 2013 | 03:33 PM
handifletch
try this link fuel pump wiring diagram - Ford F150 Forum
Old Apr 15, 2013 | 04:46 PM
I appologize, I didn't make that very clear, my mistake.
He actually cut both the lines in the tank plus the wires on both sides.
Yes, it does have the Diagrams, but the tank area isn't very clear. It doesn't show if the Yellow/White wire goes to the sender or the pump itself.
Thank you Handifletch, I'll check the link out.
Old Apr 24, 2013 | 04:22 PM
Thumbs up
I want to thank you guys for your input and help, With your help I wired and installed the puel pump, I installed the tank back in place and had the wife run the key, It started right up with no problems.
Once again thanks guys!
Old Apr 24, 2013 | 06:13 PM
IslandBlueV10's Avatar
IslandBlueV10
Glad to hear you got it going.
Old Apr 24, 2013 | 08:09 PM
handifletch
ATTA BOY'S ALL AROUND
ken kirkland
1997 - 2003 F150
Mar 21, 2019 07:21 AM
Bbqguy
13
Jul 30, 2017 09:12 PM
Troyus
15
Feb 26, 2017 11:40 AM
jimmy dale
Sep 28, 2011 07:22 PM
Onus
Sep 20, 2011 10:25 AM
