E-brake cabel interfereing with trans install.
Old Apr 14, 2013 | 10:48 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Hi all, I apologize in advance for a very basic and embarassing question to ask. Is there a trick to routing the E brake cabel over or around the bell housing, when reinstalling a c4 in an F1, without pulling the trans cover? Ive got the trans sucurly on a t jack, and a couple guide bolts (with heads cut off) so it should just slide rite in, but everytime I get close to the proper height, the e brake cabel binds somewhere and prevents front or rear movement. Ive played with it all afternoon by myself but for safetys sake I dont want to do to much shaking or forcing while Im under a truck on stands. Yes the Torque converter is in all the way (3 clicks). I dread pulling the trans cover, because it has so much sealant, paint ect and really should be replaced with a new taller one, wich I cant afford at the moment. I think the answer is obvious but I thought it wouldnt hurt anything but my pride to ask, b4 I start chipping away at another can of worms tomorrow. Thanks
Old Apr 15, 2013 | 12:08 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Disconnect the cable clamp on the crossmember, it should give you freedom to swing the cable out of the way. It lays right on top of the BH on a stock flathead.
Old Apr 15, 2013 | 08:33 PM
tinman52's Avatar
tinman52
Welder User
Yep, those cables are really stiff. Real PIA to work around.
Old Apr 15, 2013 | 09:00 PM
yamagrant's Avatar
yamagrant
I'm with them Jim. Dissconnect the cable and move it away. You don't want to bugger up your hand's like before. Good luck, and take care.
Old Apr 15, 2013 | 10:20 PM
underthebridgejim
FTE fan
Thanks guys, I ended up taking Wifey shopping today, but will try tomorow. I didnt know if Id get a response to this question, but as always, you guys have been there and done that B4. Your help is as always, very much apreceiated.
Old Apr 16, 2013 | 06:29 PM
Mervy49's Avatar
Mervy49
I had a problem similar to yours. I'm using a 351w with a c-6 and I didn't have the clearance for the b cable, shifter cable, and speedo so I made a new trans cover. The store bough ones are a little too low and expensive anyways. I'll try and get a pick in here for you. If you want to make one yourself it's quite easy.
Old Apr 16, 2013 | 10:50 PM
underthebridgejim
FTE fan
Mervy, thank you for sharing the layout of the tranny cover, Yours sure came out nice, course your whole cab is super cherry.
tjc transport
May 6, 2016 03:08 PM
tjc transport
May 3, 2016 12:07 PM
tjdad62
Jan 10, 2013 09:36 AM
Franko72
15
Sep 22, 2011 09:30 AM
