ScanGuage II or AeroForce?
Old Apr 15, 2013 | 09:44 PM
honeydew's Avatar
honeydew
I always display EOT because it's a good way to tell when the engine is up to temp. Usually also display IPR, ICP, and volts. None of the fuel use stuff will be accurate until you calibrate it and only remains accurate if you stay in the same tune. P1211 can indicate a sticking or bad IPR.
Old Apr 16, 2013 | 01:47 PM
Turfzilla's Avatar
Turfzilla
I think the SGII is a great tool for the $$. I have not had a SEL light that it would not clear yet. I usually have: EOT, IPR, ICP, and BST for non towing. I will watch trans temp when towing.
Old Apr 16, 2013 | 02:23 PM
honeydew's Avatar
honeydew
Good to know that it will read and clear codes that trigger the light. I had only ever tried it with soft codes which is wouldn't read.
Old Apr 16, 2013 | 02:54 PM
Atc210's Avatar
Atc210
what does the IPR and ICP tell you? Is there anything I should be watching for?
Old Apr 16, 2013 | 03:40 PM
theenforcer's Avatar
theenforcer
https://www.ford-trucks.com/forums/1...l#post11870633
here is a link to what all the sensors do IPR and ICP are a little down the page.
hope this tells you what you want to know
cheers mate
josh
Old Apr 16, 2013 | 03:43 PM
honeydew's Avatar
honeydew
ICP is the pressure in PSI shown by the sensor measuring HPOP output. If you program in the HPOP x-gauge it will show the same value but it won't display HPOP x-gauge and ICP on the same screen since they are duplicate values.
Here is my understanding of what you should see with stock tuning:
ICP should be 480-550 at idle and ~1800-2500 at WOT.
IPR is expressed in percent and should be 10-15% at idle and up to 65% at WOT.
Old Apr 16, 2013 | 06:30 PM
Atc210's Avatar
Atc210
I have been really watching those 2 numbers and at idle I am right in that range. Same with WOT but have seen it spike up to 3000 a few times. Thanks for the information. Now I have a baseline so if anything changes I am sure you all will here from me.
Reps sent =0)
jbodin18
Jul 17, 2011 10:28 AM
Liquid10Rider
Oct 20, 2010 08:08 AM
don77
Jan 25, 2010 07:15 PM
scubajt
Jan 18, 2007 09:47 PM
carwash
Oct 5, 2005 07:52 PM
