E4OD problem
Old May 13, 2013 | 10:04 AM
  #46
raystankewitz's Avatar
raystankewitz
Originally Posted by Cowboydesperado
SHOUT IT FROM THE MOUNTAIN TOP.......IT RUNS.....lol Well I did it. A little tuning on the motor and I think she'll be good. Only issue is it wants to cut off when I put it in R now. I may have messed a sensor or something up. Gonna check on here and see but any ideas would be appreciated. Thanks for everyones help and advise on here for this.
Sounds like you have it. Check the MLPS adjustment and look at the harness around the transmission. I'm sure you'll find the culprit.
Ray
Old May 13, 2013 | 02:11 PM
  #47
Encho's Avatar
Encho
The Southernmost Mod
I'm betting the trans is lacking some ATF and the filter is just barely hanging there, that would cause the truck to try to kill the engine every time you put it in "R". In the mods link there is also an idea for a custom filter clip, it should prevent that from happening. Great job on that trans so far!.
Old May 16, 2013 | 08:41 PM
  #48
Cowboydesperado's Avatar
Cowboydesperado
Fluid is full, May try to drop the pan and check the filter....did have to move the trans around alot to get it in by myself.
Old Jun 4, 2013 | 07:52 PM
  #49
Cowboydesperado
Turns out it just needed to sit level for a few days and then started up and I guess filled up the converter and got the fluid going. Transmission works fine now. THanks to all who posted and helped. If anyone needs help just let me know and I'll do what I can.
70Mustang
Oct 21, 2010 02:35 PM
trackenator
Dec 12, 2009 09:57 AM
sdilecce
Oct 18, 2006 08:03 PM
TRKR_MAN
Mar 9, 2004 01:25 AM
