E4OD problem
Old Apr 28, 2013 | 10:26 AM
  #31
88LX5.0H's Avatar
88LX5.0H
This is basically what he's describing
Old Apr 28, 2013 | 11:53 AM
  #32
raystankewitz's Avatar
raystankewitz
That's It!
Yeah, we made our own when I was teaching at Sequoia Institute, before it became part of Wyotech. I made mine with .015"' wire on one end and .030" wire on the other. the handle was made from some cheap aluminum tubing. Any hobby shop should have the K&S wire rack to get the wire from.
Ray
Old Apr 28, 2013 | 12:32 PM
  #33
Cowboydesperado's Avatar
Cowboydesperado
Ok I pulled it down and found one of the two teflon sealing rings on the forwrd clutch shredded. Could this be the cause of my problem?
Old Apr 28, 2013 | 02:29 PM
  #34
raystankewitz
Hmm . . .
As they would say in Minnesota, You Bethcha!
The ones inside the clutch or on the center support?
I think you're good to go now. Be careful with your reassembly!
Ray
Old Apr 29, 2013 | 11:18 PM
  #35
88LX5.0H's Avatar
88LX5.0H
Lube, lube, lube. Lube is your friend BTW.
Did you not replace all gaskets and seals in the rebuild or did these just tear from installation?
Old Apr 30, 2013 | 10:47 AM
  #36
Cowboydesperado
Think I got in a hurry and forgot to replace these. They are the original looking orange teflon seals and the ones in the kit are steel so ......my fault. Hope this fixes it.
Old Apr 30, 2013 | 01:26 PM
  #37
Cowboydesperado
Houston ..we have a problem....... Ok went to put in the steel rings but they will not slide in the two grooves the teflon ones came out off. Not tight but not slide in at all and yes I made sure these were the right size. The other steel ones go in nice and smooth. Any ideas?
Old May 1, 2013 | 09:29 AM
  #38
raystankewitz
Wrong part
If they don't fit the groove width, they are the wrong ones, regardless as to what was printed on any packaging they came in.
Take your pump and forward clutch housing with you when you go to get new sealing rings. I've seen this before with generic fleabay kits.
Ray
Old May 1, 2013 | 09:21 PM
  #39
Cowboydesperado
Went ahead and ordered the teflon ones from a transmission shop so we'll try again this weekend.
Old May 1, 2013 | 09:34 PM
  #40
Encho's Avatar
Encho
The Southernmost Mod
Let's hope that's all you need to solve this issue.
Old May 2, 2013 | 12:53 AM
  #41
raystankewitz
Go for it!
Use your assembly paste (fancy vaseline) to stick those rings to the center support. lube inside the drum before you assemble and test with air as soon as the gearset is in and the pump is torqued.
Good luck!
Ray
Old May 5, 2013 | 03:10 PM
  #42
Cowboydesperado
Ok seals will be here Monday and I'll get to work on it sometime this week. Will let ya know the outcome.
Old May 5, 2013 | 06:42 PM
  #43
raystankewitz
You do realize, once your Ford friends find out you have successfully been through an E4OD, you are going to be the "Go To" guy for transmission repairs?
Better to play it off . . . "Well, it shifts hard, slips a bit too, etc, etc." Don't let on you know about transmissions. Everyone is your friend if it gets out.
I'm confident you have it now.
Ray
Old May 11, 2013 | 03:39 PM
  #44
Cowboydesperado
You've got a very good point there Ray....lol I got it all back together and did the air test and got a nice clear thump for the forward clutch pack this time....no hissing. Having lunch right now and then back to put it back in the truck and see how she goes. Anyway thats the update for now.
Old May 12, 2013 | 08:52 PM
  #45
Cowboydesperado
SHOUT IT FROM THE MOUNTAIN TOP.......IT RUNS.....lol Well I did it. A little tuning on the motor and I think she'll be good. Only issue is it wants to cut off when I put it in R now. I may have messed a sensor or something up. Gonna check on here and see but any ideas would be appreciated. Thanks for everyones help and advise on here for this.
