rough idle
Old Apr 13, 2013 | 08:39 AM
nduclet351's Avatar
nduclet351
rough idle
I have a 99 expedition 5.4 it recently blew a plug on cyl 3 I used a timesert kit put a new plug and coil started it up and let it run for an hour ran smooth idle was fine went to drive it and about 15miles later I was going up a hill and it started to miss really bad and exhaust fumes were horrible now it idles at 1000rpm and is rough when you step on the gas you do smell gas under the hood so i think it might be a bad coil but no cel yet the new coil was a cheap az valuecraft one but theres also a collapsed vacuum line that goes into the side of the intake plenum
Old Apr 13, 2013 | 11:08 AM
lv2race's Avatar
lv2race
Originally Posted by nduclet351
Theres also a collapsed vacuum line that goes into the side of the intake plenum
You may have answered your own question. Is that the PCV hose? If so, maybe your PCV is stuck and you need a new one. Remove it and see if it rattles when you shake it.
Old Apr 13, 2013 | 01:37 PM
nduclet351's Avatar
nduclet351
it tee's off the pvc directly into the side of the intake but it was like that when I started it initially when it was running smooth but im gonna replace it anyway hopefully thats it
2001f1505.4
Mar 31, 2014 09:54 AM
jcline_mo
Feb 15, 2012 08:30 PM
Jeff Dodson
Jan 4, 2010 09:52 AM
Andrew Ortiz
Jun 20, 2007 11:58 AM
