Sponsored by: Real Truck
Rough Idle
Old Jun 17, 2007 | 01:09 PM
Andrew Ortiz's Avatar
Andrew Ortiz
Rough Idle
Washed engine on my 5.4 lite and now the engine has a rough idle?
Old Jun 17, 2007 | 06:42 PM
high ho silver's Avatar
high ho silver
You probably have moisture in one of your COPs. (coil on plug)
Old Jun 17, 2007 | 07:24 PM
playsinmud's Avatar
playsinmud
I've got the same rough idle at first startup but it goes away after 30-45 seconds. New plugs air filter gas filter.. don't know what to do next... Once its hot it runs fine
Old Jun 17, 2007 | 08:23 PM
heidiandmax's Avatar
heidiandmax
You might also have some moisture down in the spark plug tubes(?).
Old Jun 18, 2007 | 07:35 AM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
ya i got the same problem. change the cop it works wonders. even though they are $125 each.
Old Jun 18, 2007 | 08:37 AM
hydro_37's Avatar
hydro_37
Also check all the electrical connections. Water is a nasty thing on the modular engines.
Old Jun 18, 2007 | 09:24 AM
Andrew Ortiz
Checked all plugs and pulled, dried with air compresser, clean out throttle with cleaner, cleaned MAF, new PCV and still rough idle.
Old Jun 18, 2007 | 10:23 AM
redford's Avatar
redford
FTE Leadership Emeritus
Check for error codes.
Old Jun 18, 2007 | 10:29 AM
Andrew Ortiz
How or where can I get my codes checked.
Old Jun 18, 2007 | 12:07 PM
redford's Avatar
redford
Try your local Autozone.
Old Jun 18, 2007 | 12:44 PM
EaTmYtAiLpIpEs
you need someone with a computer who can pull them up. did any lights come on on the dash like the check engine.
Old Jun 18, 2007 | 01:00 PM
Andrew Ortiz
Not warning lights appeared on the dash.
Old Jun 18, 2007 | 01:12 PM
EaTmYtAiLpIpEs
funny cause mine did. and i took my truck to work and plugged the good ol' snap on into it. and i pulled up a misfire on 5. and thats when i was told that there were no plug wires and I never realized that when i bought the truck. and I really dont wanna pay $125 for the coil and crap. but I'm gonna have to.
Old Jun 18, 2007 | 11:00 PM
Andrew Ortiz
Went to Autozone and no codes appeared and I pulled each plug and made sure they were dry. The truck still idles bad.
Old Jun 19, 2007 | 08:30 AM
redford's Avatar
redford
Sounds like you have at least one bad COP. The Autozone code reader probably couldn't read precodes.
You need to buy a COP, use it to replace the existing COPs one at a time until the miss goes away.
Also, in case no one has told you, washing your engine is not a good thing to do to a Ford modular engine.
