Sponsored by: Real Truck
Replacement Dorman ABS Sensor
Old Apr 12, 2013 | 06:41 PM
Piolet's Avatar
Piolet
I broke one ABS sensor recently and took a chance on a $46 by Dorman on Amazon.
It came as shown below in a box with instructions, a note to call customer service if there was an issue, a new bolt, a small quantity of lube in a plastic bag. The clips for the frame and the one that bolts to the hub were already installed.
The entire item looked clean and brand new like plastic straight from the factory ...
.... however the sensor at the tip looked used??? Maybe that came from testing?
The connector end "boot" was loose on this one and could easily be slid back to expose the wires and attachment point. The Simplex Timken one I was replacing was much more robust in that area.
It took a good bit of effort to get it into the hole the old one came from.
However, it works. I'll find out eventually how long it lasts for.
ex0r
Escape & Escape Hybrid
Apr 10, 2017 07:49 AM
Capt.Schenk
Jul 25, 2012 08:30 PM
Mazz
Jul 10, 2012 08:15 AM
beamundson
1997 - 2003 F150
Mar 28, 2012 04:23 PM
