Carbs/need quick answer please
Old Apr 16, 2013 | 08:56 PM
MIKES 68 F100's Avatar
MIKES 68 F100
i prefer the percys adjustable secondaries kit ,just a turn of a screw .
Old Apr 17, 2013 | 05:44 AM
70-360fe's Avatar
70-360fe
Closer Look: Percy's Adjust-a-Jet Metering Plate - OnAllCylinders
I'll check it out, thanks.
Did not get to far into the carb but accerator pump looks new, don't think it has seen any gas. Spring inside vac is chrome and not purple. Might get into it a little more tonight.
Old Apr 17, 2013 | 11:38 AM
JEFFFAFA's Avatar
JEFFFAFA
The chrome (Holley calls "natural") is one step stronger than a purple one. IThe natural one wil open the secondaries a little slower and not as far compared to a purple one. FYI. In order of strength going from the strongest to the weakest they are Black,Brown, Natural, Purple, Long Yellow, Short Yellow,White.
Old Apr 17, 2013 | 11:57 AM
MIKES 68 F100
OPPS MY BAD GOT THE BRAND WRONG , should have been quick fuel
this
Adjustable Vacuum Secondary
Old Apr 17, 2013 | 08:15 PM
70-360fe's Avatar
70-360fe
this
Looks interesting have/do you use one? Is it a good product quality wise.
Took a while but finally found a price, not bad.
Vacuum Secondary Parts
Old Apr 17, 2013 | 09:54 PM
MIKES 68 F100
Yes i have one on my holley 750 ,haven't had an issue with it . another FTE member gave me this tip
use a paper clip on secondary arm to help get adjustment correct . i have mine currently set so i have to floor it to get secondaries to open (gas saver)
check ebay they have them new real cheap !
Old Apr 18, 2013 | 05:35 AM
70-360fe's Avatar
70-360fe
Great thanks for the info, I'am to ebay right now. Got to be a lot easier then messing with springs.
Corkwheats
13
Nov 8, 2012 02:56 PM
dohc_chump
Jul 29, 2011 06:19 PM
ddh1
Sep 4, 2009 11:20 PM
highboy
May 25, 2005 11:43 PM
johnwhipple
Oct 20, 2002 01:44 AM
