Carbs/need quick answer please
Old Apr 12, 2013 | 07:03 AM
70-360fe's Avatar
70-360fe
I can get an edelbrock 1406 600cfm and a hollie 4150 650cfm, 100.00 for both or 50.00 a piece. Both would most likely need a rebuilt. Was thinking about getting both then decide which would be better for my truck. So should I get the edelbrock, hollie, both or neither and just look for an edelbrock new/ in better shape. The edelbrock I'am use to, the hollie I wanted to get to play with. Thoughts
Ok forgot going on an 390fe with an edelbrock 390 performer intake, stock motor. Thanks!
Old Apr 12, 2013 | 11:21 AM
HIO Silver's Avatar
HIO Silver
I'd get both of them.
Old Apr 12, 2013 | 11:31 AM
JEFFFAFA's Avatar
JEFFFAFA
I'd get them both also. See if you can con the guy in to giving you the fuel rail for that 4150 also.
Old Apr 12, 2013 | 07:43 PM
70-360fe's Avatar
70-360fe
Just got home from work, going to give the guy a call and see if he still has them. Wanted to pick them up this morning before work but guy was not available till afternoon. Thanks for the replies, I will ask about the fuel rails.
Old Apr 13, 2013 | 07:29 AM
70-360fe's Avatar
70-360fe
Picked up both last night and both outside look good. The edelbrock does not a choke on (Not a big deal) but did come with a choke cable. Asked about fuel rails but no luck. Thanks for the help guys!
Old Apr 13, 2013 | 10:43 AM
JEFFFAFA's Avatar
JEFFFAFA
I took an Edelbrock off my transplanted 460 to go outside the box and install a Autolite 4300. So I have the electric choke cap if you need it. My 1st choice for doing the "Ford on a Ford" thing would have been a 4100. But I couldn't resist the Lincoln 4300 I bought on Ebay for $25.00. Or if you want to keep it cable choke like I did my 4300, you can go to your local Checker,O'reilly,Pep boys etc and get a Dorman brand universal choke kit. Commomly seen with all the parts they display down the "HELP" isle. The Dorman and HELP part number is 55101. It comes with a cable which you don't need, cable bracket, choke cap, choke lever for carb.
Old Apr 13, 2013 | 10:40 PM
70-360fe's Avatar
70-360fe
Really don't mind manual choke and he did give me a cable to go with it. In Atlanta don't need it much anyway. Right now I'am just trying to learn/ID the holley. Was told it was a 4150 650 cfm just trying to make sure before I buy everything for set up. Here is the ad with pics.
Holley, Edelbrock, Quadrajet Carbs, HEI Distributor, Radios, CB Radio
Old Apr 14, 2013 | 06:52 AM
70-360fe's Avatar
70-360fe
Looks like I might have a 4160 600cfm and not a 4150 650. Ran the numbers on the front of the airhorn at holleys site it tells me it's a 4160 600cfm. Airhorn numbers 80427, underneath those numbers are numbers 1376.
http://1970mgr.org/_HolleyCarbs.htm
Looking at the pics mine looks almost exactly like the 600cfm. There is no metering block on the right of the carb making it a 4160. So pretty sure that's what it's. From info you guys give me I'am thinking the 4160 would be suited to my 390?
Carb. Primary Secondary Primary Secondary Pump
Carburetor Model CFM Renew Trick Needle Main Main Jet Metering Metering Nozzle Size,
Part No. No. Kit Kit & Seal Jet or Plate Block Block Power Valve Primary
R80056 5200 280 N/A N/A N/S 124-231 124-247 N/R N/R N/S 0.023
R80057 5200 280 N/A N/A N/S 124-132 124-135 N/R N/R N/S 0.023
R80073 4175 650 N/A N/A (16,17) 122-642 N/S N/S N/S 125-213 0.037
R80086 4360 450 N/A N/A N/S 124-199 124-550 N/R N/R N/S 0.028
R80095 2305 500 37-1536 37-933 6-504 122-55 122-73 N/S N/R 125-85 0.035
R80098 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S 125-215 0.028
R80099 4180 600 37-1536 37-933 6-517 122-622 N/S N/S N/S 125-218 0.028
R80111 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S 125-216 0.028
R80112 4180 600 37-1536 37-933 6-517 122-622 N/S N/S N/S 125-217 0.028
R80120 2305 350 37-1536 37-933 6-504 122-52 122-65 N/S N/R 125-85 0.035
R80128 4175 650 37-1537 37-933 6-510 122-582 N/S N/S N/S 125-211 0.031
R80133 4180 600 37-1536 37-933 6-517 122-611 N/S N/S N/S 125-216 0.028
R80134 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80135 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80136 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80137 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80139 4175 650 37-1537 37-933 6-510 122-592 134-21 N/S N/S N/S 0.037
R80140 4175 650 N/A N/A 6-510 122-642 N/S N/S N/S 125-213 0.037
R80145 4150 600 37-1539 37-933 6-504 122-68 122-70 N/S N/S 125-65 0.031
R80155 4175 650 37-1537 37-933 6-510 122-632 134-21 N/S N/S N/S 0.037
R80163 4180 600 37-1536 37-933 6-517 122-622 N/S N/S N/S N/S 0.028
R80164 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80165 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80166 4180 600 37-1536 37-933 6-517 122-612 N/S N/S N/S N/S 0.028
R80169 4175 650 37-1537 37-933 6-510 122-543 34R5113-3 N/S N/S 125-211 0.025
R80186 4500 750 37-1539 37-933 6-504 122-70 122-70 N/S N/S 125-65 (15) 0.028
R80186-1 4500 750 37-1539 37-933 6-518-2 122-70 122-70 N/S N/S 125-65 (15) 0.028
R80186-2 4500 750 37-1539 37-933 6-518-2 122-70 122-70 N/S N/S 125-65 (15) 0.028
R80318-1 4160 600 703-33 N/A N/S 122-74 N/S N/S N/S 125-65 0.040
R80319-1 4160 600 703-47 N/A 6-511 122-65 N/S N/S N/S 125-25 0.025
R80320-1 2300 350 703-30 N/A N/S 122-61 N/R N/S N/R 125-50 0.028
R80340-1 4500 1050 37-1539 37-933 6-504 122-84 122-84 N/S N/S 125-65 (15) 0.035
R80364 4150 450 703-28 N/A 6-511 122-59 N/S N/S N/S 125-85 0.021
R80402-1 2300 500 703-36 N/A 6-511 122-75 N/R N/S N/R 125-45 0.028
R80431 4160 550 37-119 37-933 6-506 122-60 134-9 N/S N/S 125-65 0.025
R80432 4160 550 37-119 37-933 6-506 122-60 134-9 N/S N/S 125-65 0.025
R80436 4150 850 37-1539 37-933 6-504 122-80 122-80 N/S 34R11698AQ 125-65 (22) 0.04
R80443 4150 850 703-58 N/A 6-504 122-88 122-96 N/S N/S 125-65 (15) 0.031
R80450 4160 600 37-1536 37-933 6-506 122-622 134-39 N/S N/S 125-208 0.031
R80451 4160 600 37-1536 37-933 6-506 122-622 134-39 N/S N/S 125-208 0.031
R80452 4160 600 37-1536 37-933 6-506 122-652 134-39 N/S N/S 125-208 0.031
R80453 4160 600 37-1536 37-933 6-506 122-632 134-39 N/S N/S 125-208 0.031
R80454 4160 600 37-1536 37-933 6-506 122-622 134-39 N/S N/S 125-208 0.031
R80457 4160 600 37-119 37-933 6-506 122-69 134-39 134-128 134-39 125-65 0.031
R80457-1 4160 600 37-119 37-933 6-506 122-64 134-39 134-128 134-39 125-65 0.031
R80457-2 4160 600 37-119 37-933 6-506 122-64 134-39 134-128S 134-39 125-65 0.031
Old Apr 15, 2013 | 01:42 PM
JEFFFAFA's Avatar
JEFFFAFA
Are you sure 80427? Sometimes they didn't stamp them well. The pic you posted is a classic 4160. Vacuum seconary,fuel transfer tube,etc. But my Holley book says a 80427 is a 4150,700 CFM,double pumper with a secondary metering block, with all 4 bore diameters of 1 11/16" diameter.
Old Apr 15, 2013 | 09:54 PM
70-360fe's Avatar
70-360fe
Yea some how I made a mistake, cleaned it up and on the airhorn it has 80457 underneath 1376. Been looking at some pics and found an installion manual almost certain it is a 4160 600cfm. PO stated it is 4150 700cfm, guess that's how i can with the 80427 number.
Do you thing this model would be better for my application?
Old Apr 16, 2013 | 09:05 AM
MIKES 68 F100's Avatar
MIKES 68 F100
R80427 IS A MARINE CARB
80457 is a good carb ,600cfm square bore electric choke single inlet ,4160 comes with the ford kickdown linkage . it could have adjustable floats depending on how old it is .
google says use 37-119 kit
Holley 37-119 Holley Carburetor Rebuild Kits
Old Apr 16, 2013 | 09:50 AM
JEFFFAFA's Avatar
JEFFFAFA
Correct there Mikes 68 F100. It is all as you stated according to my Holley book. Including the externally adjusted floats. I can see them in the picture. And to make it even better, It is almost exactly the formula I replied a few days ago. It already has the #39 secondary plate. It has #64 jets where I said #65. To make up for that it has #31 accelerator pump nozzles where I stated #28. The only thing I have against it is if the PO did not change it already, it has a black spring in the secondary spring pot. That is the strongest one Holley makes. Which means your 390 will never open up the secondarys all the way. I stand by my reply a few days ago and say try the purple spring 1st. Along with the Holley numbers I gave you then, Holley #37-119 is in deed the "renew" kit. Or if you want some extra gaskets and tuning parts, #37-933 is the "trick" kit. YOUR 390 WILL LOVE THIS CARB. When you are ready let me know. I'll explain the best way to get that fuel transfer tube and it's "o"-rings installed.
Old Apr 16, 2013 | 07:07 PM
70-360fe's Avatar
70-360fe
Thanks for the replies! Jeffafa I will let you know when I rebuild, could be 2 to 3 weeks. Still have to finish doing my tilt steering column and get the headers and manifold on.
PO said it had been rebuild a couple years ago and never used. It does look clean outside, I might open it up tonight to see what the inside looks like.
Found this online and my carb does have the adjustable float.
http://www.jegs.com/InstallationInst...0-0-80457S.pdf
Old Apr 16, 2013 | 07:33 PM
JEFFFAFA's Avatar
JEFFFAFA
Cool! Figure 16 on page 12 shows the spring I suggest trying a purple one 1st. If he rebuilt it he may have changed the jets or etc. While you are in there check the numbers on the jets and the secondarary metering plate to match my earlier reply. To check the accelerator pump nozzles you don't have to remove them. Open the choke flat and look down at the front center. You should see a big phiilips screw retaining the nozzle body. If it still has it's original #31 there will be small brass tubes (the actual nozzles) sticking out of it pointing to each primary throat. #28 and smaller were orifices in the nozzle body, no tubes. Note, most rebuild kit come with the two check ***** in a Holley. But just in case I'll tell you where they are so you don't loose them. One is bellow the accel pump nozzle body. in the same hole as it's phillips retaining screw. If your carb has a bolt there then under the nozzle will be a needle instead of the 1st ball. The second is in the 5th hole of the secondary spring pot. You'll see it once you remove the lid.
Old Apr 16, 2013 | 07:53 PM
70-360fe's Avatar
70-360fe
Thanks for the info. I will let you know what I find. Lost the little steel ball when I rebuilt my 2100, was concerned I might do the same thing with holley. Now I know what to look for, thanks!
